Question about iiyama LS 704U 17" CRT Monitor
Problems with monitor settings
Hi, I'm having problems with the display settings of my monitor. The settings menu keeps appearing on and off repeatedly. I've tried reconnecting the monitor and also leaving it off for a little while, but the the problem does not seem to go away. Please help
  • Anonymous Dec 21, 2007
    i also have the same problem..the contrast panel come out and can exit it..how to fix it?
  • 741963 Dec 23, 2007
    i dont think the buttons are the problems as i hardly ever press them, but if the buttons need to be replaced, do i simply just pull them out or somthing?
    Problem Solver:
  • 10 Answers
You need to replace the front panel control buttons,
Regards,
Aby
Posted on Dec 22, 2007
  • Aby Paulose
    Aby Paulose Dec 24, 2007
    Hai , To replace the Front panel buttons you need to open the back cover of the monitor or contact any local repair shop.
    regards,
    Aby Paulose
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Resolution problem
reset your computer and press F8 F8 immedeatly and keep pressing untill menu appears .then highlight on enable vga mode and press enter your problem will be solved thenk you
Jun 25, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
Volume Menu appears randomly; buttons 2-4 don't work reliably
Once you can try providing "reset" option from the menu .... This will solve most of your problems ..
Jul 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
On screen display keeps appearing on, and usually
hi..i think you have a problem the CPU/Computer that's whystays on screen for so long.1st step check the IDE cable connection form the mother board to Hard Drive and 2nd check the memory or check all hardware`s.Good Luck and Have a nice day
Jun 17, 2009 | HP mx705 17" CRT Monitor
Problem on hp monitor
The problem should be defective keypanel.Try replacing the switches .
It should solve your problem.
Please provide feedback and rate this solution.
Samir.
Apr 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor menu problems
Hai Ejor,
You need to replace the front panel menu buttons,
Regards
Aby
Nov 18, 2007 | AOC LM729 17" LCD Monitor
Problem with Control Panel
It sounds like theres a front panel button that has become intermittant and making contact all by itself. Sometimes when you clean the screen, the cleaner will drip down between the crt face aqnd the cabinet and make the switch in front go bad. Im not sure if this is the case in your problem but its a start. If you didnt spill anything or drip anything into the front panel then your maicroprocessor could be causeing the problem, or the 5 volts that feed the micro could be noisy ie, bad filter capacitor in the power supply. Now as im sure your aware of the hi voltage inside these sets? Its best if you dont have the training to get a pro to assist you as this hi voltage can hang around inside the set even if its unplugged. Good Luck
Jul 03, 2006 | SAMTRON 55V 15" CRT Monitor
iiyama LS 704U 17" CRT Monitor Logo
197 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
RS Technology...
RS Technology...
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
