Question about Honeywell Programmable Thermostat Heater
I just bought a honeywell RTH230B thermostat and it uses 5 wires Rh Rc W Y G and the current thermostat is a LUXPRO electric heat and cool with 6 wires C(Blue) G(Black) R(red) W2(White) O(orange) B(not used) Y(brown) E(jumped from W2) how should I wire up my honeywell with the existing wires? Thank you, Fred
  • 80 Answers
This thermostat will not work for your application. You need a Heat Pump thermostat. A comparable stat would be a Honeywell TH4210D1005
Posted on Oct 04, 2009
Changing a White-rogers 1f83-041 thermostat for a honeywell rth230b
Should be a factory installed jumper between rh and rc. This stays and red goes to either. Y is yellow G is green W is white. Black will get capped and not used. Just means your tstat will always require batteries.
May 17, 2017 | Heating & Cooling
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B cooling problems...
I printed out the instructions for your thermostat. It looks like you should have the following.
There should be jumper wire between Rh & Rc
Red wire to Rh or Rc whichever is easier since there is a jumper. This is the hot wire and all the thermostat does is connect to route it to the components needed for heating or cooling.
Blue wire, tape it up and don't use it. There is no spot on this thermostat for it. It is only used on thermostats that are powered by the transformer.
White wire to W. Powers the heat relay
Yellow wire to Y. Powers the cooling contactor
Green wire to G. Powers the indoor fan relay
There is a black jumper on the back of the face plate. Look at section 2.4 Setting J2 Jumper in the installation instructions. Make sure you have it in the right position for what you have. If you don't have them just google them.
Hope this helps.
May 24, 2010 | Honeywell Electronic Programmable...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Replacing Old York TS to HoneyWell RTH230B
rh is hot for heating rc is hot for cooling looks to me like ya need a heat pump stat some thing to control the reversing valve.Tom
Jun 18, 2009 | Honeywell Electronic Programmable...
RTH230B thermostat not working - nothing's happening
The 2nd combination is correct (w/ jumper). Wire nut or tape the blue wire. The snow flake shows it's going into cooling mode after a 5 min delay. If the AC is not coming on then the problem may not be the thermostat. If you don't have 24VAC between the red wire and the blue one the problem is at the furnace or it's supply. If you do, then check for 24VAC between the blue wire and Y on the thermostat(after the 5min delay) - if it's there the thermostat is calling for cooling. To check the heat, switch the thermostat to heat mode and use the W(instead of Y) on the thermostat(after the flame stops flashing).
Apr 02, 2009 | Honeywell Programmable Thermostat Heater
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Honeywell RTH230B
Jumper RH to RC and Y to W (Just like the old thermostat) and hook the cable wires as you have indicated with the exception of the blue wire - clip it back - it is not needed. This is a heat pump system so heating and cooling are done by the same unit. RH stands for Red Heat, RC for Red Cool, the W and Y are the neutral sides to the heat and cool control circuit. That should get you going good enough to start learning the intricacies of programming the box.
Jun 02, 2008 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
I have my temp on C and I need to change back to F I have the RTH230B programable
May 30, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
589 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
