Question about HP Photosmart C4180 All-In-One InkJet Printer
My hhpc4180 says check color cartridge and checked
My hpc4180 says check color cartridge and checked still will not even print black /the cartrige is not a hp but worked when it was full
Soulvisitor
  • 1113 Answers
SOURCE: new cartridge problem
Machine needs both cartridges working to work
Posted on Nov 30, 2007
SOURCE: Hp K80 printer
I had the same problem, and it seems to have corrected itself. I too, installed a new "45" black cartridge and got the message to remove and check color cartridge. After I removed it and cleaned it the message stayed on the display for about 5 minutes and then asked me to "align cartriges." After I aligned them I had no problems.
Posted on Jan 25, 2008
nitinbabbar
  • 55 Answers
SOURCE: HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
thnx
Posted on Jan 28, 2008
  • 214 Answers
SOURCE: HP Laserjet 4650 color printing problem
More than likely you need new drum.
Posted on May 06, 2009
pagebor
  • 2785 Answers
SOURCE: how to use HP printer 6210 without color cartridge
you cant print when cartridge is empty.
Posted on May 18, 2009
Replaced new ink keeps saying right cartrige is incorrect wont let me print. the cartrige is correct i paid $50.00 for a two pack of black and color ink!!!
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One InkJet Printer
Print with single cartrige. I rarely use color. The color cartrige ran dry and nothing will print in b&w until I buy a new color cartrige ( for about $37.50) and install it. HOW DO I BYPASS THIS...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up and prompt you to chose this option, you should be able to tell the printer to print in black .
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | HP Office Equipment & Supplies
I replaced both cartriges (Black and Color) and when I print, the yellow color does not print. Even on the test page, the color setion at the bottom is blank where the yellow color block should be printed....
You can dab the bottom of the color cartridge on a damp paper towel, check the streaks left behind, if there is no yellow either there is no yellow in the cartridge or it's just plugged. Dab it a few times on a wet towel, if still no yellow, you need another cartridge.
Dec 22, 2009 | HP DeskJet 932c InkJet Printer
Just had my color cartridge refilled, and reinstalled correctly. However, the printer will not print with the color cartridge in, but will print with the black cartridge only.
your newly installed cartrige which is the colored one is not detected or mybe damage....may i ask if how many times did you refill already your cartrige?refilling a cartrige can cause damage to its circuit i suggest purchase a new colored cartrige and see if it works.
Oct 09, 2009 | HP DeskJet 845c Printer
What type of ink cartriges are used in the lexmark 5400 model
hello there
here is the lexmark ink cartridges #31 for color and #32 for black 18c0031us_sm.jpg #31 Photo Color Print Cartridge (18C0031) $ 34.99 QTY 18c0032us_sm.jpg #32 Black Print Cartridge (18C0032) $ 24.99 QTY 18c0533_sm.jpg Twin Pack #32 Black Print Cartridge (18C0533) $ 47.99 QTY 18c0033us_sm.jpg #33 Color Print Cartridge (18C0033) $ 26.99 QTY 18c0534_sm.jpg Twin Pack #33 Color Print Cartridge (18C0534)
Sep 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer Cartrige Problem [Tri-Color]
if the printer queue is empty and you have turned both comp and printer to off it should reset.
Frpm your explanation it sounds like your color cartridge has a problem Tricolor red,blue, yellow maybe one is empty the black is a separate cartridge
Jun 21, 2009 | HP J4680 Office Jet All-In-One Printer
Color won't print! Test shows continuity.
I stand corrected, but this sounds strange. The black cartrige on a 650c is a no40, the colors are No50. It is impossible to place a color cartrige in the black posotion. You must remove all your cartriges and wipe them off at the bottom with a very hot wet cloth (not boiling) Let them stand on the wet cloth for quite some time and then give them a good shake (dont be shy). Be VERY careful not to get ink on your clothes or nearby objects. Once you have done this wipe them down again with a dry lint free cloth or tissue paper and try again.
Dave
May 18, 2009 | HP DesignJet 750c plus InkJet Printer
Printing with only the Black ink cartrige.
Yes. The printer won't operate without both cartridges installed, even if one is empty.
Mar 15, 2009 | HP DeskJet 842c InkJet Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
Printing in black only on HPC4180
Click on Start> Settings/Control Panel> Printers and faxes> Right click on the default printer icon and left click on Properties> under properties you will see Printing references> there you see a option to use black cartridges only select it and apply and ok.
And try to print.
If not whenever you ptint any document you will see the printer where you can make selection of printers, even there you can right click on the printer and choose to print only in black.
Good Luck
Jun 29, 2008 | HP PhotoSmart C4180 All-in-One Color...
HP Photosmart C4180 All-In-One InkJet Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
