From a CLEAN computer download and put on a flash drive.
Copy to your DESKTOP on the suspec computer.
Run it but dont change any options just use what it offers.
When its done let it clean anything it finds.
Its where I always start with an infected machine.
As for antivirus AVOID Norton or Mcafee but try the AVG FREE version MBAM should clean up without buying
Only continued use would require purchase As for too many applications that would be up to you to decide what you REALLY need and dont. Most toolbars are a waste of both time and space and can hog computers down. Maybe a good clean up is in order ?
It may just be a "leaking application"
These are badly coded programs that dont release memory when they should and just keep taking more to do the same job.
It is a program that can make a report on what you have running in such a way that you can post that information to certain sites and experts there will look at it.
They will then give you reccomendations as to how you can remove programs or fix some issues that may be upsetting your computer.
Dont post the log here but follow the nstructions and help the program offers to send it to one of the sites it will offer you.
If you understand startup lists you may even be able to spot som things yourself that you dont want to run and disable them from hijack this.
Have refilled Dell black cartridge but the printer will not print with black this time. Any help...
(More)
Have refilled Dell black cartridge but the printer will not print with black this time. Any help would be appreciated.
driver s/ware will not d/load to my laptop.Dell aio 942.Dell site no help,.Was already installed but...
(More)
driver s/ware will not d/load to my laptop.Dell aio 942.Dell site no help,.Was already installed but got wiped by a virus,will not reinstal
My dell 942 AIO printer will not accept the new black cartridge I have installed. Still gives...
(More)
My dell 942 AIO printer will not accept the new black cartridge I have installed. Still gives "install black or photo cartridge on LH side. I have been refilling the cartridges prior to getting this new cart, which I think is a remanufactured cart. I was told at one point there is a way to fool the printer into accepting refilled cartridges - can the same be done with remanufactured cartridges, or do I have to try a real/new Dell cartridge?? Have already powered printer on/off, cleaned print heads and cartridges, and reseated power brick. Any other suggestions welcome. .
