Question about Sony Cyber-shot DSC-W90 Digital Camera
Lens will not fully extend; receiving message to power off then back on. Still not working despite multiple attempts.
  • 3 Answers
SOURCE: Zoom shutter wont extend fully
the same thing happened to me. I took my camera apart - just removing the case. I then operated my camera and it became "unstuck". now it works just fine. I put the case back on and all is just as before.
Posted on Jun 28, 2007
  • 69 Answers
SOURCE: W1 lens not extending properly
Lens is damaged. not economic to repair
Posted on Sep 21, 2007
  • 34 Answers
SOURCE: Casio EXILIM camera lens will not extend fully!!!
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. Hint...google my username. ;)
Posted on Jan 25, 2008
  • 34 Answers
SOURCE: lens error
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them. The good news is it can be fixed....Casio most likely won't help. Hint...google my user name.
SOURCE: Lens Error - Restart Camera : Lens remains in extended position.
Hey,
I had the same problem as everyone else regarding the error that would pop up stating that there was a lens error. I had the camera in my pocket when I went to a hockey game, pulled it out to take a picture, and it didn't work. Needless to say I was pissed because I expected far more from Canon. I was just about to go and buy a new camera, and figured that I would try to troubleshoot the problem and stumbled upon this site. Someone suggested turning the camera on and off while twisting the lens, so I figured it couldn't hurt to try it.
Before trying this, my lens would not retract all the way, the cover would not shut, the image was blurry, and I could not zoom in at all or the camera would show the error.
So, I tried the "twisting" solution, and it wasn't working, but I think I was being too delicate with it. I put a little more pressure on it and gave it a good twist. There was a clicking noise as others have said, but in the end, it worked after about 2 or 3 minutes of messing with it. No my lens goes down, the cover shuts and its clear as a bell. Not sure if this is a recurring problem as it appears to be a common problem, I fully suggest trying this before you send it off to get it fixed for a ridiculous amount of money.
Best of luck
Posted on Jan 30, 2009
When I turn on my Canon G6 power shot 7.1 megapixels it starts to work and then right when the camera turns on it turns off. I checked the batteries and they were fully charged. After the camera turns
Hi Cayley,
Typically, when an electronic or electro-mechanical device - such as a computer or as in this case - your camera - is powered up; it goes through a "boot up" so to speak. Like your computer, the camera electronics performs some quick, basic checks on the electronic and mechanical systems during the boot up sequence. This often includes checking for the presence of a memory card, battery charge state, connection to a computer via USB cable - and - checking the lens position; and if it can be extended and reversed to a "home" position or not.
Because you're seeing a "lens" message, this is a clue that the camera boot up sequence has detected some sort of problem with the lens. Most often, the problem is tied to the lens not moving or not moving *fully* due to grit or sand lodged between 1) moving parts of the lens or 2) between moving parts of the lens and the stationary parts of the camera body itself. When you turn on the camera, does the lens move in and out - like it did before? If not, that is probably the cause. You can 1) send the camera to be repaired by Canon, 2) have a local repair shop attempt to fix it, 3) replace the camera with new - if it is older than a few years as it may not be worth the cost of investing $$ in old technology - or if this option is your plan, 4) attempt repair yourself. You have nothing to lose - you can try to help the lens extend by pulling while it s"boots" up if it is retracted - or pushing in on it if stuck in an extended position. That is the NORMAL test at boot - to extend then fully retract. You may get it to work, abd save the cost of repair or replacement - or you could damage the mechanism even more.
I hope this helps & good luck!
Mar 24, 2014 | Canon "infrared" Power Shot G6 7.1 Mp...
Lens error, restart camera is the error message I get when trying to turn on the camera. The lens will not fully extend and just starts to wiggle back and forth then I get the error message when the...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 27, 2010 | Canon PowerShot S3 IS Digital Camera
I just got a canon powershot sd 1400 is for christmas and i charged the batttery and then put it in my camera and automatically came up was lens error automatically shutting down
Make sure that the battery is charged fully. It may not have enough power to operate the lens on startup. If the battery is charged fully, and it keeps doing this, take back the camera tomorrow to the store that you bought it from.
For others reading this, that did NOT just receive a brand new camera that you can take back to the store. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try. (jillmur3, don't try these. take yours back to the store)
Dec 25, 2010 | Canon PowerShot SD1400 IS IXUS 130...
EasyShare Z885 Digital Camera: unable to power up camera. lens remains fully exte...
If the lens makes a partial movement when you attempt to power up, it is probably dirt/sand that has jammed up your lens in the extended position. First use a vacuum to remove dirt between the lens gap. Next, be very careful, but when you power up, as the lens tries to retract apply a little force to help the lens, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera
May 17, 2010 | Kodak EasyShare Z885 Digital Camera
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Casio Exilim Z40 - Lens Error Message
You can try to "fix" this problem by holding down the shutter release button as soon as the camera power up.If this does not work you will need to replace the lens assembly. This should only be done by a qualified tech.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the servo motors to "smoke".
Apr 25, 2009 | Casio Exilim EX-Z40 Digital Camera
Cannon G7 need help
Hi
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Jan 21, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Problem
I had the same problem and fixed it.
The problem is related to the lens not working properly and jammed up.
When powering on the camera, the focus goes in and out and the lens spin and then the message is displayed to turn camera off.When I turn the camera off, I noticed the lens did not fully hiberate into the camera like it did before the error message.
So to fix the problem I did the following:
Turn the camera on, when the lens extended out, I slightly rotated the outer most lens clockwise and counterclockwise to free the lens from the jammed position.
The error no longer appeared and the camera stayed-on.When I shut the power-off the lens completely hibernated again like normal.
Hope this helps.
Pete
Dec 25, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Dec 14, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Sony Cyber-shot  DSC-W90 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
