Question about iRiver H10 MP3 Player
Delete music H10 iriver
How to delete my music on my H10 iriver
  • rducky8085 Feb 23, 2008
    OK, my iRiver freezes, and when I'm able to bring 'my playlists' up, there are no songs. No songs at all anywhere on the device whatever I try. the playlists remain, and my PC says the memory is still full (or whatever capacity is still filled).
    I try to erase all the songs and start over, but my PC takes 20 mins just coming up with the file menu. I can't access the song folders at all...it searches for hours until I give up
    Scholar:
  • 73 Answers
Sorry, but the built-in firmware only allows you to do that by plugging it into your computer as a removable device. Pull the battery of the player (or press the reset button), plug it into your computer, and press and hold the OK button as you turn it on. This will cause the computer to recognize it as an external drive, and you can therefore delete music from it by accessing it through My Computer.
Posted on Dec 25, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: Deleting from my Iriver h10
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Then reformat inside of Windows Media Player
Posted on Jun 26, 2008
SOURCE: Iriver H10 V's Vista
Try making sure the device is switched off before plugging it in - then turn on the power after it's connected.
Seems to've fixed the problem for me.
Posted on Aug 15, 2008
SOURCE: cannot delete or add music to iriver h10
I had this problem at first too. the only thing you have to do after it's done syncing disconnect it and turn it on. then afterward go through the options till you find database refresh and wait for it to refresh and all your new music should be in it.
Posted on Jan 14, 2009
  • 17 Answers
SOURCE: Cannot delete musice from iriver h10 need to know
I presume that you are running the original firmware with windows media player to add your music.
There is an option on the Sync screen to delete.
Let me know if you are not using WPM to add your track to your h10
Posted on Jun 23, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: how to delete music off an iriver H10
when h10 is connected open file find the file you wish to remove right click and delete
Posted on Aug 19, 2010
How to delete music off an iriver H10
Oct 07, 2009 | iRiver H10 MP3 Player
Can not delete files
you can try fomatting it.to do so plug it and open my computer.go to the drive of the mp3 and right click it.in the sub menu click format(to foramt it you have to be administrator)(also be sure backup all of your music,videos,pictures,and anything that you want to save.)
Jul 25, 2009 | iRiver H10 MP3 Player
Cannot delete musice from iriver h10 need to know how
Jun 09, 2009 | iRiver H10 MP3 Player
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Cannot delete or add music to iriver h10
Jan 04, 2009 | iRiver H10 MP3 Player
4.6GB Iriver H10 Merory says 2.9GB remaining but there is nothing on the player.
Considered formatting disk?
For you what this would mean is just a complete refresh of the device (you will lose everything).
You will need to read everything carefully.
Check this out
http://www.misticriver.net/boards/showthread.php?t=14853
I converted my H10 to the "UMS" mode mentioned in the site a long time back (so I could directly transfer files as a USB mass storage device) and had the issue mentioned in that post. Works great. Converting to UMS mode is done here http://www.misticriver.net/wiki/index.php/H10_Firmware_Conversion:_MTP/UMS
You will also need the iRiver Plus software that you can download for free here http://www.iriver.com.au/iriver/index.cfm?pageID=10001&
Feb 17, 2008 | iRiver H10 MP3 Player
Deleting files iriver h10
i can usually get them off thru windows media (sync tab but then make sure your clicked on the photos tab etc) but sometimes i need to go into it as if it is an external harddrive thru windows explorer
Just to let everyone know I have the H10 6Gb player and the reason your having problems getting the H10 to work with Vista is because it isn't supported by Vista at all even with updating your firmware...
Dec 23, 2007 | iRiver H10 MP3 Player
Sync itunes to Iriver h10
well itunes only works with the ipod for syncing music, windows media player 10 and 11 is where you would sync you music i would add your music to the media player library and go from there
Jun 29, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
994 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
