Question about Lexmark Wireless X4850 All-In-One Inkjet Printer
Printer is showing as not connected via wireless but will also not print though usb
rjwharris
  • 102 Answers
SOURCE: 'Communication Not Available' message when printer cable connect
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Posted on Feb 21, 2009
smartr10U
  • 1305 Answers
SOURCE: Can't print from MacBook, through Time Capsule, to Lexmark x5470
turn on the printer sharing via the system preference panel on the computer that is on the system via usb.
Then on your wifi computer look for shared printers and you'll see your printer in the list under the host computer name... use that setting and it should fire up for you!
let me know how it goes...
Posted on May 28, 2009
  • 14 Answers
SOURCE: Hey, i recently got a Mac and tried to connect my
You stated you have a mac. Is your Mac a laptop that provides wireless? Or are you on a Mac desk top connected to a router that has wireless included with it.. If you have either than you need to go into your network and sharing to set-up the wireless printer. This will give you access to your router via desktop or your wireless settings via laptop,
Once there if you are already using wireless settings you are going to have to allow your printer in through your wep or wap encryption settings. This was set up when you first started using your wireless to keep out intruders.
Posted on Mar 08, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: wireless printer communication unavailable via USB
    Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
    Posted on Mar 26, 2010
    etaf
    • 779 Answers
    SOURCE: my lexmark x4650 is supposed to print wirelessly.
    reset the network connections Procedure: Resetting the Network Settings
    1. Press Setup ().
    2. Press the right or left arrow button until Network Setup is displayed, and then press .
    3. Press the right or left arrow button until Reset Network Adapter Defaults is displayed, and then press .
    4. Press the right or left arrow button to display Yes, and then press .
    5. Observe the message "Clearing Wireless Settings".
    6. NOTE: You will not be able to navigate the menu until this process is complete and the Wi-Fi light resets from to orange ().
    http://support.lexmark.com/index?page=content&id=HO3371&actp=search&viewlocale=en_US&userlocale=EN_GB&segment=SUPPORTproductCode%3D&productCode=LEXMARK_X4650&searchid=1270310780939
    Guides available from this link http://support.lexmark.com/index?locale=en&segment=SUPPORTproductCode%3D&startover=y&userlocale=EN_GB&question=Lexmark_X4650&productCode=LEXMARK_X4650&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X4650&searchid=1270310775279#3
    Network Guide available from here - under documentaion http://support.lexmark.com/index?page=content&actp=PUBS&locale=en&segment=SUPPORTproductCode=&userlocale=EN_GB&id=PU45811&productCode=LEXMARK_X4650
    Use guide http://support.lexmark.com/index?page=content&actp=PUBS&locale=en&segment=SUPPORTproductCode=&userlocale=EN_GB&id=PU45810&productCode=LEXMARK_X4650
    Posted on Apr 03, 2010
    Tip
    I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
    (1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
    As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
    Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
    Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
    on Apr 25, 2010 | Office Equipment & Supplies
    I can not get anything to print on my Epson NX420 using my IMAC. It says the printer is offline and I can't even print a test page. Can you help?
    I'm assuming the printer worked previously from the iMac and now it does not. If you never had it connected, please add a comment to this effect, and include your OS version.
    First, Open the Print Center (Printer Utility) and check the status of the printer. It may be listed as stopped. If so, delete any extra print jobs (additional attempts to print the page), then click the Start Jobs icon.
    You can verify printer connectivity by clicking Add in the Printer List (if that is not visible, select Show Printer List from the View menu). Be sure to select either the USB or wireless network protocol connection. If the NX420 shows up, you have a good connection. In that case, click cancel and skip the next paragraph.
    If you are printing via USB, check the cable (I sometimes forget to plug in my printer cable after downloading from my camera). If you are printing via your wireless network, check the status of the wireless connection from the printer.
    Also, in the printer utility window, click the Supply Levels icon to verify that all of the ink cartridge levels are high enough to permit printing.
    Are there any error messages on the printer display? A fault detection will take the printer offline.
    Jun 22, 2011 | Epson Printer
    To whom may it concern, I current have Canon MX340 and I tried to print out some papers but it showed "Printer not responding" What should I do now? Thanks, George
    George,
    It sounds as though either the printer is not talking to the pc or the pc is not talking to the printer.
    Unfortunately you do not say how you communicate with the pc. Is it wireless or via usb?
    I would probably reinstall using the cd if its a wireless setup. Can you print via usb? If you can then do the above.
    Repost if you are still stuck.
    Jun 20, 2011 | Canon PIXMA MX340 Wireless Office...
    Wireless printer communication unavailable via USB
    Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
    Can I make this a wireless printer?
    You can connect the printer via USB to a single PC or via Ethernet on a network. Though it doesn't have wireless capability built-in, you could also connect it to a wireless router or a print server for a shared wireless connection.
    Dec 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
    My Lexmark T622 just wont print!?
    It is problem your copier configure,you try to print via usb cable then you get a dicission
    Sep 12, 2009 | Lexmark T622 Laser Printer
    Connecting from a Mac via wireless print server
    Dissconnect USB cable add ethenet cable find printer on Mac set to default should work fine then worry about the wireless side inkypete
    Apr 21, 2009 | HP OfficeJet 6310 All-in-One Printer...
    Lexmark Wireless X4850 All-In-One Inkjet Printer Logo
    18 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
