Question about Sharp AR-M237 Digital Copier
Causing PC to turn off
Sharp ar m237 HP Pavilion with Vista
When we print from IE e-mail. It shuts her computer off. Her computer programs are all up to date, this is the second sharp copier that has had this problem, previous laser printers did not have this effect on her computer. Could it be a driver problem? Has anyone else had this problem?
  • wallan May 11, 2010
    I have alot of these copiers connected to all brands/models out there. I have not had this problem.
  • 63 Answers
The only way her computer would shut down is because the computer is telling it to shut down. Their might be a driver issue but I have not had or heard of this problem on the 100 or so that I have worked on. Completely remove any Sharp software from the PC (add/remove programs). Restart PC and got to http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx to download the most current drivers. Make sure that you have UNPLUGGED the copier form her PC if printing my USB or Parallel.
Posted on Oct 17, 2009
Sharp AR-M237 driver
You can download any driver you need from the link below.
Also, there are instructions for installation linked on the page.
Sharp Print Driver Download 64bit and 32bit Free Printer Driver Download
Jun 29, 2014 | Sharp AR-M237 Digital Copier
I have a sharp AR-M237 printer and when I try to print is telling me Error: PostScript printing not license for this printer
You need to get the correct driver for printing Post Script. You need to buy the program with the licence to print post script. Good Luck
Jan 06, 2013 | Sharp AR-275 Copier
How do I change the IP address for the scanner on a Sharp AR-M237 multi function
Custom Settings/Admin mode/ passworrd 000000 print settings/ network settings
Aug 27, 2010 | Sharp AR-M237 Copier
Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Oct 08, 2009 | Sharp AR-M237 Digital Copier
U2-40
Push P * C* in quick succession to enter simulation mode. Once there, enter 16 on the keypad. push the print button (like making a copy). Push 1 for yes then print button again. push the CA button. Copier should reboot and run fine for you.
Apr 01, 2009 | Sharp AR-M237 Copier
XP machine can't print from Vista machine
sharp drivers usally requirt port software 1p2p type set up mot as easy as ho ot lemark should sonsult local service in your area
Feb 24, 2009 | Sharp AR-M237 Copier
Create fax from my HP window vista computer to Sharp AR-M162
Won't work with Vista unless you spend $100 for some fax program
Feb 20, 2009 | Sharp AR-M162 All-In-One Laser Printer
Faxing
You need Option, AR-FX7 (FAX) installed, real easy to figure out, look at the side, if you see a telephone line, with line and telephone connections (not the Network connection) then you have a fax.
Next your arm237 will also need to be able to print from the nextwork.. if this is all together..
you will need a driver called, PC to Fax for the AR-M237.
which you can find at www.sharpusa.com
Then you will have to set up the computer in the printer folder to PC to Fax.
Sep 29, 2008 | Sharp AR-M237 Copier
Windows Vista Printer Driver
Go to: http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
and select the copier and OS that you use. Download the PCL5e driver. When you finish downloading, you might have to extract it from the zip format, then run the setup.exe file and follow the prompts.
Don't forget to rate your answers please!
Mar 14, 2008 | Sharp AR-M237 Copier
Sharp AR-M237 Digital Copier Logo
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
