Question about Rockford Fosgate Punch 400W Class AB Bridgeable 4-Channel Amplifier w/ Variable Crossover
Not enough Amp?
It powers my 2 12" punch subs full force then after a few minutes i lose all sub-noise. Is my amp too small?
    President:
  • 2,187 Answers
You should still get sound even with small amps but it would be rather weak. Check first the source of the signal. Test with different sources to be sure. Check for loose connections.
Posted on Oct 02, 2009
What subwoofer speaker is suited for punch 200m?
this is a full-range amp suited best for full range speakers,however it can still be used for a sub. you want a sub whose max RMS is 150 watts or less.
May 11, 2014 | Rockford Fosgate Punch 200M Car Audio...
Hi i have a few questions. I have bought a dual 12 " sub box and i need 2 subs and one amp to go with it. I want intence base that will impress! I am currently looking at 2 Alpine SWR-12D4 they are...
It's been my experience,that intense and low bass comes with a price,always remember u get what u pay for,so on that note,Try to get Rockford Fosgate Competition subs with a punch 250 or 500 trust me that it is a powerful combination.and if u can afford it get a choke to put on ur subs so they will only kick bass put tweeters in the dash and mid range speakers in the door u could use a dual rca jacks to install 2 amps at once and get a punch 45 amp for the tweeters and mids.hope this was helpful
Apr 03, 2013 | Car Audio & Video
Amp worked fine one day and the next day i get nothing. the red light on the side is on but i dont get any sound. i took the subs that were wired on that amp and wired them on the other punch 800 i have...
did you check all fuses on amp and coming from battery power wire? also check the ground and rca cables connecting to the unit and make sure the remote wire (small blue wire) didnt come lose thats usualy a sign for the red light
Mar 26, 2011 | Rockford Fosgate Punch 800a2 Car Audio...
Why do i need to open my gain up to 3/4 to full turn inoder to achieve a loud bass?Im using punch 2400 amp and 2 12" kicker.
the amp may not be powerful or your setting on the cd player is not right try adjusting the cd player. turning the gain all the way up will damage your subs even go above halfway
Sep 19, 2010 | Rockford Fosgate Punch 801S Car Audio...
My punch 550.2 amplifier's thermal light is turning on and off
well, hopefully the amplifier was wired correctly. But either way there are so many factors that can cause this problem... But the biggest one is the amplifier must have been sending some distortion to your subwoofers which a subwoofer can take a certain level of distortion and be fine but too much will blow any subwoofer even the highest of high end subs at a high volume... when your subs hit the point of blowing they will tend to just blow out one at a time... they don't just pop both right away. I'd say get the sub that isn't blown off off of the amp before it blows too... distortion is clipping most of the time... when you destroy the subs it will eventually work it's way to the next component in the system which is your amp and then you will be out an amplifier and subs. save yourself the headache.......
Dec 12, 2009 | Rockford Fosgate Punch P550.2 2-Channel...
I have a rockford fosgate punch 150 and it will power a small 5 1/4" speaker, but doesn't seem to push my 15" subwoofer. I am reading 4ohms across the sub so I'm assuming that it is fine and that there is...
amp is way too small to power a 15 inch sub. But you should get some sound out of it, not silence. You can use a 9 volt battery to test your sub, if the sub pops when the 9 volt is placed across it's terminals then it's ok. If it does not pop then your sub may be bad, or the coil may be frozen. (It can still read 4 ohms if frozen). If your amp powers smaller speakers fine, you know it's not the amp. If the sub tests ok, then verify your connecting it properly to the amp's correct bridging terminals.
Jun 12, 2009 | Rockford Fosgate Punch 150S Car Audio...
What kind of noise it will bang or should i go with class d amps
If you run a pair of subs to each amp at a 4ohm bridged load per amp you will get the full power of the amps delivered to your subs-roughly 450 watts per sub as punch amps are all under rated-that sh%&t gonna bump hard - thats an incredible setup from an equipment standpoint- i run 1600watts on a pair of 15z and its freaking obnoxiously LOUD and yours will be moving more air than my 15s so it should be just mind numbing - go for it !!!!!!!!
Jun 04, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Amplifier loads
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
I think my ex blew my amp
model number? im thinking 401s? if so that should be the only light on
Aug 07, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Amp Issues
1) Make sure a bridged load of no less than 4 ohms is applied.
2) make sure both the left & right channels are working.
Jan 29, 2008 | Rockford Fosgate Punch P2002 Car Audio...
Rockford Fosgate Punch 400W Class AB Bridgeable 4-Channel Amplifier w/ Variable Crossover Logo
146 people viewed this question
Top Rockford Fosgate Audio Players & Recorders Experts
 Grubhead
Grubhead
JonSnell Electronic
JonSnell Electronic
Are you a Rockford Fosgate Audio Player and Recorder Expert? Answer questions, earn points and help others
