Question about Kenmore 62602 Electric Dryer
No heat I have a part number 3979705 kenmore dryer. I push the push to start switch and it starts the dyer and rotates but no heat and as soon as I take my finger off the switch, it stops. Thanks for your help John
  • Kenmore Master
  • 7,482 Answers
Sounds like you have two problems John.
1. Sounds like you could have a faulty motor run capacitor.
2. Sounds like you have a faulty heating coil or thermostats.
If you have a front load machine, remove the front. This will expose the drum and belt, remove the belt and this will expose the drum rollers, idler arm with pulley, and motor. This will allow you to check out the motor.
I hope this helps
Posted on Oct 03, 2009
I have a Kenmore Elite part no. 3979705. I push to start and the motor started but did not continue to run when i take finger off button. I have check the thermal fuse, door switch and it is good. What...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 12, 2011 | Dryers
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
Kenmore electric dryer 90 series part# 3405768 kit # 27918 problems. The dyer heats up, the bulb at the door lights, but the dyer doesn't hum neither does it rotate to dry clothes! I'm unable to locate the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 24, 2011 | Dryers
I have an older kenmore gas dyer. as soon as the door is shut it starts running with out pushing the start button, and it doesn't shut off till you open the door . is it the start switch or the timer that...
Good day,
It could be either the push to start switch, or the centrifugal switch on the motor. You would need an ohm meter to check the push to start.
The way the system works, is the power goes first to the door switch, and then the timer.
If the timer is in the on position, it sends power out on TWO wires.
One goes to the push to start switch, which in turn goes to the motor, bypassing the centrifugal switch.
The other power wire goes to the centrifugal switch, and thru it to the same place on the motor, but only if the motor is already up to speed.
That's why it under normal conditions it will continue to run when you release the start switch.
Hope that helps.
Thanks for using FixYa
Jan 27, 2010 | Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Dryer will not turn on
your motor switch is bad you need to replace the mmotor
Mar 02, 2009 | Kenmore 62602 Electric Dryer
Kenmore Elite Dyer Model # 11071082000
Hi. thanks for the question. the problem you have is with the coils ,on the gas valve. 2 little coils . replace them. thanks the appliance doc
Sep 30, 2008 | Kenmore 72802 Gas Dryer
Kenmore dyer
sounds like the timer, unless it has a Evenheat contol board and a seperate motor relay, in which case its most likely the relay, or could be the computer
Sep 29, 2007 | Kenmore 64892 Electric Dryer
Kenmore 62602 Electric Dryer Logo
120 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
