Question about Whirlpool Duet GHW9150P Front Load Washer
When washing a load it keeps beeping and reads H F.
Read H F
  • 220 Answers
F/H
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
Posted on Oct 02, 2009
  • Whirlpool Master
  • 3,361 Answers
Either your hot water is not turned on or your water valve is defective.
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
Error code f 50 stop and keep beeping
washed to small bathroom rugs.. on bulky items. low suds stopped at F code and can not get to rinse and drain and whole dial lit up. Tried removing one rug of 2 to lighten the load. still not working. Tried unplugging it and waiting. have had about 2 years. HELP.. read the directions.. it appears using bulky items was not wise. over did the agitation.. made too much suds?
Jul 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Last cycle completed, maching beeped and washing taken out. Machine light is on rinse cycle and beeps will not reset to start new load.
Hi just read your posting.From the information in your posting you mentioned that the rinse light is on when the machine is beeping.Starting from the left to right on the wash progress lights which lights are lit when the machine is beeping,Is it the 1st and 6th or the 3rd and 7th etc?Please reply with this additional information and i am sure i can help you rectify your machine.Looking forward to your reply.
May 17, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washing machine keeps stoppping.
Hi just read your posting.Now when the machine starts to beep it will show a series of lights.These lights will be in a row of 8 lights.Starting from the left to right which ones are lit when the machine is beeping?Is it the 2nd and 5th or the 4th and 7th ---etc---?Please reply with additional information and I can help you further.
Jul 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
My front load washer keeps beeping even when there
Beeping is pretty vague, but here it goes. Read the very broad answer. Your answer will be in it. I hope this helps.
LOOK HERE
May 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Beep will load is running
This sounds like the same problem I had. It turned out to be a loose solder joint on the potentiometer for the water level. A few minutes with a soldering iron and it was fixed. I'm not an appliance tech but as near as I can tell, any input from any button or knob will turn the machine on and/or create a beep. Therefore, a loose connection at various places on this board could cause the same problem. I have also read about a lot of control board problems with various kenmore appliances. I suspect many of them may have a similar cause. Hope this helps.
Mar 19, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Machine beeps but won't start
does it say do in the display as if the door is open??
Oct 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Mar 12, 2007 | Maytag MAH6500 Neptune Front Loading...
Whirlpool Duet GHW9150P Front Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
