Question about Maytag Dryers
I AM TRYING TO DOSCONNECT THE THRMAL FUSE FOR THE MAYTAG CLOTHES DRYER. i REMOVED THE SCREW BUT THE FUSE IS CONNECTED TO THE HEATING CHAMBER WITH A WIRE. I CANNOT DISCONNECT THE WIRE FROM THE FUSE CONNECTOR... ANY IDEA HOW?
  • Maytag Master
  • 3,361 Answers
Pull really hard.
Posted on Oct 02, 2009
We have a Maytag Legacy Series gas dryer, that was working fine but just when we went to turn it back on it stopped working.we check the gas and gas is fine the electricity is on so I'm not sure what if...
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Feb 17, 2015 | Maytag Dryers
Maytag Neptune MDG6700AWW Gas Dryer runs for 2 min then goes to cool down. Why is it shutting down?
Thermal Fuse
Air Flow and Heat
Warning
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 18, 2014 | Maytag Dryers
MAYTAG DRYER FLAMES KICK ON FOR 5 SECONDS THEN CLICKS OFF
Thermal Fuse
Air Flow and Heat
Warning
May 03, 2014 | Frigidaire Electric Dryer
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a Maytag PYE2300AYW, I am on my third round of replacing the High Limit and Thermal Fuse. I am at a loss on what could be the main factor for this. It almost seems as if the heating element is...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 09, 2011 | Maytag Dryers
The heating element went out and the machines are not old enough for that, I wouldn't think but it isn't heating up or drying.
Before replacing the heating element, I would check the sensors that are attached to the heating chamber. They can be disk shaped with two wires connected to it. Also there may be a thermal fuse in that same area with two wires connected. Check those parts with a continuity tester or ohm meter after the wires have been disconnected and with the dryer unplugged. The thermal fuse runs about $20.00 dollars or so depending on the model.
Jun 11, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My maytag electric dryer wont heat up
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Clothes dryer not producing heat
Check voltage at the receptacle first. The motor and timer operate on 120VAC. The heating element requires 208/240VAC to operate. Remove power from the unit. You can check the heating element, thermostats and thermal fuses using an ohm meter across each components terminals with one wire removed. The thermal fuses and thermostats should read zero ohms. The heating element will read low ohms (20 to 40). Successful heater operation still depends on the motor centrifugal switch being closed. Depending on the model, you need the heat circuit in the timer or electronic control to be closed.
I hope this helps you.
Apr 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer isn't heating
You never mentioned if you checked the large klixon mounted above the heater.If it is bad you will have no heat but the dryer will run. If the thermal fuse (mounted on the right hand side of the heater chamber, 2 white wires) is bad then the dryer simply will not run. If it is good then the next thing you need to check is the control thermostat mounted on the blower housing. While down there check to see if that wheel is loose. If the control thermostat is ok then you have a bad contact inside the timer. Sometimes you can clean the contacts in the timer like cleaning points on a car.
Dec 10, 2008 | Maytag PYE2300AY Electric Dryer
Danby dryer DCD5505W will run but does not heat.
it might heating be the heating element or thrmal fuse. ck both .
Apr 14, 2008 | Dryers
Dryers Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
