Question about Sunpentown 9000 BTU Portable Air WA-9010E Air Conditioner
User manual Hi I need to find a user manual for a Kelvinator air con KSR25F. Ta. Ross
I have a kelvinator ksr25f split system.The green light on the front panel flashes when the unit is turned on.The unit cools ok and when the temp is cool enough the outside unit stops as normal but doesnt...
Check and make sure the outside fan is running. The KSR series Kelvinators were rebadged LG units. It is possible the 6uf fan capacitor on the outside unit has failed.
Mar 04, 2014 | Heating & Cooling
I have a Kelvinator Reverse Cycle air conditioner - Model # KSR25F-01. When I use the heating operation the "Defrost Mode" has come on and is stopping the air conditioner from working. The unit...
The Kelvinator technician came out and found that our gas was very low indicating that there was a leak somewhere - the gas should never deplete apparently (being a closed system). He checked inside and outside and couldn't find a leak so assumed it must have been an issue with the piping in the walls. He recommended not spending the money to get it repaired - he recommended it be replaced (not a cheap option but it was 11 years old and repairing wasn't likely to be cheap or a long term solution). So not sure if that is your problem but hope it helps!
Jun 13, 2011 | Heating & Cooling
The unit is a Kelvinator Air Con unit - Model #KSR25F-01. The unit will turn on manually but not from the remote. The remote has new batteries, but will not start the unit. The only button that the unit...
take the remote and put it in front of your cell phone.turn on the camera of your phone and push the buttons of the remote.if you see a light in your phone the remote is ok and then the eye of the pc board(is a small plate)has problem.
Dec 06, 2010 | Heating & Cooling
Can you help i need to know how to change the receiver
Hi!!
For this job, you"ll need R22 GAS gauge set. a GAS RECOVERY UNIT, a VACCUM PUMP and a WELDING TORCH among other things, unless you have the equipment, I recommend to contact an Air Conditioning Tech, to do the job.
Click below if helpful
Apr 14, 2010 | Heating & Cooling
Water is not entering my swamp cooler. Could the problem be that the main water line is clogged up, and if so how do i check it?
hi i have a split system air conditioner ksr25f kelvinator but i cant find a manual and i dont know what the buttons on the remote send for can someone help thanks
May 11, 2009 | Heating & Cooling
Loud whistle noise kelvinator split KSR25F-01
It may be the small vent fan motor on the inside if the control panel. When the noise begins remove the panel and you may be able to catch it in the act.
Dec 27, 2007 | Carrier 36KCARMS Air Conditioner
User Manual required (Kelvinator Washing Machine)
Click on Bosch or your brand (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Dec 06, 2007 | Washing Machines
Sunpentown 9000 BTU Portable Air WA-9010E Air Conditioner Logo
75 people viewed this question
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Pete Norton
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
