Question about Heritage 30" Children's Room Ceiling Fan With Light
Light or fan will come on with without remote
  • 25 Answers
Most remotes use an X10 format that transmits over wires .. Odds are someone else in your neighborhood is on the same code. Does the light come on with regularity? If it does than that is your problem. Without knowing the exact model I can't tell you how to change the code. When you change it you must change the receiver and the transmitter
Posted on Oct 02, 2009
Remote will not operate fan or light. Replaced battery. Remote light glows red when pressed
Check dip switches in remote and dip switches on receiver in the canopy of the fan, make sure the settings match exactly. Make sure there is power to the fan. Make sure the fan and light are not manually set to off by pullchains that may be on the fan. If the fan does have pullchains, wire it directly in (bypass the remote in the canopy) and test the functions to make sure the fan and light are working. If it works without the remote, but not with the remote, and the dip switches are set the same and you have new batteries, then the remote and receiver should be replaced.
Feb 28, 2011 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter fan with remote and the light flickers without coming on completely - and you can hear a clicking noise coming from the fan. The fan works and the bulbs and batteries were changed
The pins inside the remote could have been switched or the wiring inside the fan could have come loose. Check the wiring at the fan first. The vibrations of the fan could have worked the light conrol wire loose.
Oct 10, 2010 | Hunter 27185 Remote Control
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Fan remote nor lights work.
FIRST CHECK THE WIRE CONNECTIONS IN THE FAN ARE NOT LOOSE ,IF ALL CONNECTIONS ARE GOOD THEN I WOULD SUGGEST YOU REPLACE REMOTE.
Nov 08, 2009 | Dryers
How can I fix this with fan and light turns on without remote
This might be a silly question but have you tried takeing the batteries out of the remote?
Jul 26, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote Chewed Up
i had similar problem with remote , went to home depot to buy a new fan and saw they had new remotes and receivers for the hunter fans , i bought the kit ( which had a remote and a receiver for a non remote ceiling fans) and was working again . salesman was very helpful .thanks.
Dec 30, 2008 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay ceiling fan, Remote does not turn light off
if you have the remote controll for both the fan and light you can have the controll on both the fan and light...
other wise it can't
Dec 08, 2008 | Hampton Bay 52 In. White Redington...
Fan with light (no remote) with wall switch not a 3-way
Unless you want to use pull chains, you will either have to get a different fan with a remote, or you can buy a remote to ADD to an existing fan/light. It hooks up under the base of the lamp. They seem to work better than the factory fans with the built in remotes.
Dec 04, 2008 | Hunter 52" Ceiling Fan With Light And...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Dryers Logo
50 people viewed this question
Top Heritage Dryers Experts
roeb
Ottoniel
Mike
Are you a Heritage Dryer Expert? Answer questions, earn points and help others
