Question about AMD Duron, 1.6 GHz (*dhd1600dlv1c) OEM / Unboxed Processor
Recently upgraded CPU from AMD Duron 750mhz to AMD Duron 1.6Ghz on VIA8363-686A mainboard and 7VZA chipset using BIOS version via694-42302e31,Award Modular BIOS v6.00PG,aNK7VZA ver 1.1g 12/06/2000. There is no FSB adjustment through current BIOS version. I need to change FSB from 100mhz to 133mhz. New CPU is being identified as AMD Athlon 1.2Ghz. PC is running Windows XP pro sp3 OS. How do I get processor clocked?
    Genius:
  • 1,027 Answers
Your motherboard probably does not support that speed, without a bios upgrade.
Posted on Oct 03, 2009
Testimonial: "Sorry for the late feedback. Bios flash solved this annoyance. "
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
Mar 06, 2011 | EliteGroup K7S5A Pro Motherboard
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
your max cpu would be proably 3200 anthlon xp ok
Jan 10, 2008 | ASUS A7S333 Motherboard
Want to upgrade CPU and Ram on ASUS A7V-ML motherboard
Download a small utility called CPUID from http://www.cpuid.com or use this direct download link "http://www.cpuid.com/download/hwmonitorpro/HWMonitorPro_106.zip". Using this utility you can analyze your system hardware statistics and also you can find the RAM capacity supported in your system along with various other RAM parameters. It will also show you the available free RAM slots to use, as well. I hope this is useful to you.
Aug 04, 2009 | AMD Athlon , 650 MHz (-K7650) Processor...
Changing processor results in windows xp pro failing to install
I'd try upgrading the bios with the working cpu and then try again.
Let me know what happens. I like the weird ones like this.
Feb 26, 2009 | Abit KT7A Motherboard
Trying 2 figure out what type of memory 2 use?
that looks like an Albatron MoBo but I cant get onto the albatron website to confirm this
Feature
AMD Athlon™/Athlon™XP/Duron™Processor
Socket 462 with FSB 200/266MHz
2 DDR266/200 Memory Sockets
6channel AC 97 Audio
2 ATA133 Channels, up to 4 ATA 133 IDE Devices
6 USB 2.0/1.1 Ports (4 ports by optional cable)
Integrated 3D Graphics Engine
Processor
Socket 462 AMD Athlon™/Athlon™XP/Duron™Processor
FSB / Transport
200/266MHz
Chipset
North Bridge: VIA KM266 ( VT8375 )
South Bridge: VIA VT8235
I/O Chip : Winbond W83697HF
Memory
2 * DDR sockets
DDR266/DDR200 unbuffered ECC/none-ECC DDR SDRAM up to 2GB
Expansion Slots
1 x AGP 4X slot (1.5V Only)
3 x PCI slots (PCI 2.2 compliant)
1 x CNR slot (AMR Type)
IDE / SATA Connectors
2 ATA133 channels, up to 4 ATA 133 IDE devices
Onboard I/O Connectors
1 x Floppy Connector
2 x USB 2.0/1.1 header (4 ports USB cable optional)
1 x CD_IN header
1 x COM (serial) port header (Optional COM cable)
1 x S/PDIF in/out header (S/PDIF in/out cable optional)
1 x CPU fan header with fan rotation detection function
1x System fan headers with fan rotation detection function
2 x 5 pin system panel header (Intel spec)
1 x Front audio header (Intel spec)
1 x IrDA header
1 x Case Open detection header
1 x Wake on LAN
I/O via Back Panel
PS/2 keyboard/mouse, 2 x USB(2.0/1.1),1xVGA ,1 x Com(serial), 1 x Parallel, 1x Game/Line-in/Line-out/MIC
Power
20-pin ATX power connector
BIOS Feature
2Mb Flash EEPROM
Award BIOS with ACPI, DMI2.0, PnP, WfM2.0, Green Suspend to RAM (S3), Suspend to Disk (S4) Wake on keyboard, Wake on LAN/RTC Timer
Hardware Monitoring
2 FAN sensors, CPU/System voltages and temperature monitoring.
Special Feature
Certifications
FCC, CE, BSMI,WHQL
Form Factor
Micro-ATX (218mm x 244mm)
Jul 11, 2008 | Intel Motherboard
Upgrading processor to Duron 1.4GHz
well older mother board cant handle a higher CPU processor, you have to make sure you have ALL the jumper properly set for the CPU, also the memory on the motherboard should be for that motherboard. try not to OC the motherboard as it will fry it.
Also check the motherboard for any Blown capacitor. for the MB to scream bloody murder something is definately wrong.
you could check the website of asus and look under ARCHIVE or DISCONTINUED motherboard. to find drivers and manuals for the motherboard you have unless you have them
also make sure the motherboard can actully take a higher processor.
Thermal grease is always good its help alot, just dont over do the grease applications. as ive seen pasta made out of thermal grease cpu's
Good luck
Jun 04, 2008 | ASUS VIA KT133A Chipset A7V133-C...
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Apr 03, 2008 | AMD Duron , 750 MHz Processor
MPN: A7S333
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
BIOS Type: Award
amd 3200 + anthlon ok with fsb 266 mhz soket a
AMD Duron, 1.6 GHz (*dhd1600dlv1c) OEM / Unboxed Processor Logo
219 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
