Question about Motorola Mobility RAZR V3
Battery is low, When I hook up any charger,screen says unable to charge. Is it the battery,or is something else wrong?
  • 32 Answers
Its the battery by the sounds of it
Posted on Oct 02, 2009
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
Straight talk samsung galaxy proclaim cell phone. Turns off and on by itself. Will say battery critically low but when plug in battery shows not that low. cant do browser or apps unless plugged to charger....
Its battery is weak. Even though it shows full; when the O/S loads, the CPU of the phone will take large amount of current, and the battery is unable to supply it during that time. In short; the current storing capacity; at least 1.2AMPs, should be there with the battery, but now there is not. It won't hold charge; in terms of current.
Replace the battery with new one. There is no other problem to your phone.
Gopakumar Gopalan Google
Aug 07, 2014 | Cell Phones
The charger doesn't do anything. I've charged the charger then hooked it up to the battery (pos on pos, neg on neg) then tried to start the car. No reaction whatever. Is there something else I
It's possible you may have a poor connection from your car to your car battery. Check to make sure both battery terminals are on your battery tight. Tighten them if necessary, then try again. If either one was loose, that should fix the problem. Then there may be nothing wrong with your battery charger.
Jan 17, 2013 | RoadPro Road Pro 12 Volt Dc Portable...
I have new batteries and charger but batteries will not charge
If your battery is totally flat some chargers see this as connecting to a short and will not charge. If the battery has a charge run it down some, my batteries often don't take much of a charge if any. Does the charger light up.Does the charger have any fuses on its out put wiring. Open the charger up, do you see fuses. When the charger is on do you see any blinking lights. If you get a blinking yellow light when hooked to a battery there is something wrong with the battery. Hope this helps
May 26, 2012 | Pride Mobility Products Health & Beauty
Cell phone took a ****
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Apr 15, 2010 | Motorola Mobility Clutch i465 Cell Phone
Won't charge
if the charger is good, then there is something wrong with the charging port or the battery.
If the battery is very flat before you charge, the charger would not be unable to wake the battery because the battery cell is weak. Its only a desktop charger that can wake the battery cell.
So, test your phone with another good battery, and if it still does not charge, then the charging port is bad as I said earlier.
Best wishes.
Jan 12, 2010 | Samsung M220 Cell Phone
Charging Battery
did u try to charge it connected to your pc? maybe its the charger
Feb 04, 2008 | Motorola Mobility Moto Q
Battery Charging
If both the charger and the battery are warm to the touch, the battery is probably charged.
The low battery level warning level is learned by the phone. To train it, allow the battery to run down once until the phone stops working, then recharge it.
The best way totest the charging operation would be to try using the phone. Fully charged you should get about 6 hours of talk time from a fully charged battery, and at least a week of standby operation.
Dec 25, 2007 | Motorola Mobility V176 Cellular Phone
Battery low all the time
Try Eneloop batteries from Sanyo. They have the higher voltage needed. AND that voltage doesn't sag under the initial startup load.
Nov 02, 2007 | Cameras
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
