Question about Kenmore 24032\24036 Top Load Washer
Kenmore 70 series 110.26732503: I had a drive block go bad and replaced. Now the machine wants to agitate during the start of the spin cycle (or the brake is some how engaging). Is there some timing issue I have created during assembly? Could it be the transmission located below the brake assembly and how can I check the trans without taking off the cover plate?
    President:
  • 1,937 Answers
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26732503
The first thing to check and make sure of is that the two tabs on top of the Drive Tube are fit into the correct slots in the Drive Block and that the "washer" that fits on top of the Drive Shaft (Two prongs) is mounted.
Replacing the Drive Block shouldn't affect any of the timing.
When we had to replace the Agitate Cams in the transmission on ours, we found that the agitator will turn when the washer goes into the spin cycle. This isn't hurting anything and apparently helps spin the fabric softener unit.
The brake only affects the tub and not the agitators.
It's possible that the Agitate Cams aren't raising the "Agitate Gear" fully above the Connecting Rack when the washer goes into drain and spin mode.
Following is the Whirlpool PDF on installation and maintenance of top load, direct drive washers. It has a very good explanation of how the transmission works when switching from agitate to spin.
It isn't too difficult to pull the cover off the transmission but it is a messy job.
Posted on Oct 03, 2009
  • oldguy5 Oct 04, 2009
    Sorry, following is the Whirlpool PDF
    https://secured.whirlpool.com/Service/Sr...$FILE/L-55.pdf
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Agitator does NOT spin along w/ drum during spin cycle
If this is the old style that uses a belt, it is not worth fixing. But the problem sounds like the wig-wam is not functioning properly. Most of the time it was a wire broken since it moves back and forth constantly.
Jan 28, 2010 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aug 27, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
237 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
