Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
Static lines one screen
I have a Samsung LE32R73BDX, 2 days ago, I turned on the TV to find that I have static lines running vertically through out the whole screen. I still get picture and sound, but its overlayed with static lines. The lines look mostly white, about half centimetre thick with bits of green and red. The run vertically, looking like morse code, it isnt clean cut lines. It like this for all the sources, for one of the scart source, the top 2 inches dont have the lines. Its a clean picture. Got a photo here....
http://www.paul-lee.co.uk/downloads/IMG_2672.JPG
http://www.paul-lee.co.uk/downloads/IMG_2674.JPG
I've turned off all power, unlugged wall, left it overnight, still the same.
help, please.....
    Genius:
  • 1,554 Answers
As the top is ok and the bottom has this issue.
It looks like the circuit board has a bad connection to your screen.
it is not repairable by you and not an adjustment.
you need to have it repaired.
don't you miss the old wack on the side fix?
Posted on Feb 17, 2008
Got the same problem.
Exactly like the photo.
Now i am not satified with the solution given by Mr. Coldcut because my menu and TXT is clear.
If i put on TXT on half screen i have the static disturbtion only in the TV half screen and not in teletext.
disturbtion is in all inputs including HDMI
So problem must be in PCB which has the scart and antenna connectors.
Please comment !
Posted on Aug 08, 2008
My Samsung Plasma TV has vertical lines on it. Is there a way to test the unit myself without resorting to taking it in to a repair shop??Any ideas would be greatly appreciated!!
means the glue or rubber padding on the gold static conductors are coming unstuck at the top of the screen just under the top of the plastic frame or has dirt...maybe this video is helpful, also happens to all Plasma and LCD and computer Monitors, it's definitely not a Motherboard issue it is a simple annoying fix but a real pain to get too if you have the patience.
LCD TV Repair Secrets Vertical Lines on the Screen
Apr 26, 2017 | Samsung Televison & Video
Fix samsung plasma vertical black bar
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Vizio vw42lfhdtv10a static lines
Sounds like AC line interference. Use an external line filter.
Jun 05, 2013 | Televison & Video
Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Jul 01, 2009 | Samsung 32 in. LCD Monitor TV
Samsung LN-S4692D - Vertical lines (>15) & static on screen
this sounds like a scan board gone ,, if you check ebay youll see two things,
1, other tvs for sale with the same fault (It might give you a clue to the fault ie , which board )
2, the same tv as yours with a broken screen ,
i dont know how good you are with taking things to bits but i personally would buy the tv with the broken screen and start swapping over the internal boards ?
Have you checked your home insurance policy for broken tv,s
it may have fell of its stand when you were'nt looking?
May 16, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Toshiba 27AF44 shows vertical lines and crakles very loud
The capacitors at the vertical stage must be faulty resulting in the above symptoms.
Sep 20, 2008 | Toshiba 27A44 27" TV
SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Feb 22, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
649 people viewed this question
Jerry Greenberg
Jerry Greenberg
