Question about Panasonic DMR-E85H DVD Recorder
Thanks for the solution
My E85 started showing the please wait the other night and then went completely dead. Opened the unit up and C1270. 1271, 1260, 1261 all looked bad. Used the recommend radio shack 1000 micro F capacitors to replace all 4. Though I had no confidence in my soldering job, to my surprise, the unit started up! Now , I just hope the soldering job holds. Thanks to all of those who posted here.
This really is not a problem. I was just trying to post it to the thread that had the same problem.
Posted on Oct 03, 2009
LF tracfone won't turn on
Take it to a phone sales location and see if they have new battery to fit .
Sep 26, 2015 | LG TracFone 600 Cell Phone - TF600GP4
06 Colbalt Electrical System Dead
I would go to the positive terminal on the battery anjd check for black hard build up on the post and inside the terminal. This is lead sulphate and cause a high resistance to any high current flow. Clean both with sand paper until shiny and refit and tension properly. Do the negative also as it will have build up but to a lesser degree. If the battery lead runs through a connection box Check for tight connections there also. As to towing most towers have a wheel rack that fits under the tyres and lifts them clear of the road so it can be taken to to a shop.
Feb 17, 2013 | 2006 Chevrolet Cobalt
I started my 2002 jeep overland today in the morning and everything was fine. Drove to the gas station got gas went to start it nothing. No sound no lights just completely dead. I waited a few seconds and...
I would first clean the battery post and clamps, as a bad connection can cause a vehicle to act like the battery is dead, you can either buy battery terminal cleaner( it comes in a spray can) or you can use coke and a wire brush. Hope this helped Tim
May 29, 2011 | 2002 Jeep Grand Cherokee
I have a Dell Dimension 5100 Desktop and last night I shut down normally with no issues, then waited a minute and turned off the power strip. Now it will not turn on at all, no lights nothing. I have...
Hi Martz!
After looking at your description I have to say Yes!
  • If your machine doesn't function at all that means it is not receiving power.
  • If you were unable to hear the FAN of the power unit, then there is a greater possibility that the power unit is dead.
  • But if you see any LED indicators on in any area on the mother board that means your power unit is working well or partially.
  • So first check the power CABLE. Then the power unit. You have to check both.
  • Make sure that your Processor FAN functions well.
  • Make sure that your CMOS battery is not dead (0 charge).
Feel free to contact again if the problem persists. Please rate the answer as well!
Thanks for using Fixya!
Sep 03, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
DVD Recorder frozen - please wait on display
You need to replace the STR-G6353 voltage regulator on the power supply board. Full proceedure with photos at this link: http://www.rbjtech.net/electrical/e85/e85.htm#0 I did this on my DMR-E85H and it now works like new.
May 30, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85Hp dvd won't turn on now.
The power supply board on the DMR-E85H has problems. The earlier boards suffered from leaking capacitors and the later boards from voltage regulator problems. If your machine is now dead, the fuse on the power supply board has also blown.Go to the following links for details and photos on how to fix:Replacing capacitors:http://www.fixya.com/support/t216825-dvd_recorder_frozen_please_wait_displayReplacing the voltage regulator:http://www.rbjtech.net/electrical/e85/e85.htm#0Hope this helps. My machine had the later ps board and the voltage regulator replacement worked perfectly.
May 26, 2009 | Panasonic DMR-E85H DVD Recorder
PLEASE WAIT
I contacted Panasonic about the "PLEASE WAIT" on display and after a few attempts to fix I was told that it would cost $130 minimum to repair.Then I found I had the same problem that hpwhite & RandyChev described "PLEASE WAIT" on display. I followed their very precise and informative directions and found that I also had two bad (bulging) caps, C1270 & C1271 Thanks to the pictures he posted, I was able to find replacement 1000uf 35v Radio Shack #272-1032 capacitors and replaced them with no problems. I then was able to power it back up and all of my information was still on my hard drive, even the correct time in the display. If you can find RandyChev's description with the pictures, it is very easy to understand
May 23, 2009 | Panasonic DMR-E85H DVD Recorder
Dead power supply.
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 17, 2008 | RCA DRC8300N DVD Recorder/VCR
Unit/control panel completely dead
Check your circuit breaker, "off" and "on" the breaker it my be tripped off. If it wont work may be some fuse blown in the control, or the control itself may be defective.
Jan 28, 2008 | Carrier 38CKC042 Air Conditioner
Panasonic DMR-E85H DVD Recorder Logo
293 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
