Question about Vacuums
Where do you plug in charger? I did not receive a manual or instructions with my new Roomba 560 and cannot get it started.
  • 65 Answers
There should be a little plug on the side that allows it to charge. its a small circular outlet similar to the one that would plug into any electronic from an adapter
Posted on Oct 02, 2009
Roomba 595 no lights - not charging
Just a idea but have you tried replacing the battery? Here is a link to a forum on this topic.
http://www.robotreviews.com/chat/viewtopic.php?t=2901
Dec 29, 2015 | iRobot Roomba 560 Robotic Vacuum
Room a 620 keeps stopping
It could be clogged with hair (when was the last time you cleaned it out?), it could be the battery isn't holding a charge any longer. It could be getting caught on something . How long is it running before stopping? I found I used to get about a two hour run from my Roomba, before the red light flashed. Then I started to unplug the charger and Roomba when it had a full charge and it wasn't needed. I noticed that after this the Roomba didn't run as long, maybe one hour, before needing a charge again. I leave it plugged in all the time now.
Jul 07, 2014 | iRobot Roomba 560 Robotic Vacuum
My roomba irobot 700 series is completely dead after being disconnected for several weeks?
I noticed that when I started disconnecting my charger after it had recharged my Roomba, that it didn't run as long later. So I think that the Roomba needs to be sitting on the charger with the charger plugged in. I would put your's on the charger for two days and see if that does the trick.
How mechanically minded are you? Can you get a voltmeter and check what charge is coming out of your charger now? Can you access the battery and use a voltmeter to check what charge it has?
May 10, 2014 | iRobot Roomba 560 Robotic Vacuum
I have no instructions for my roomba 560 so dont know how to start it
Turning Roomba on and off • To turn Roomba ON, press CLEAN once. You will hear a beep and the CLEAN button will light. • To start a cleaning cycle, press CLEANagain. Roomba will start a cleaning cycle. • To pause Roomba, press CLEAN while Roombais cleaning. • To turn Roomba OFF, press and hold theCLEAN button until Roomba's lightsturn OFF.
Sep 21, 2011 | iRobot Roomba 560 Robotic Vacuum
My roomba 560 approaches the dock and attempts to dock. However, it never seems to align correctly and backs out. This is a continuous process. It simply will not dock at all. Any suggestions?
Check the connector on your ROOMBA, there is a switch that open the ground when you connect the charger direct to the ROOMBA and a lot of times it get stock and remain open. Using a small screwdriver press the metal plates to force to close.
Oct 08, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba stopped after 45 minutes. does not move. manually placed on docking station...nothing
Sounds like something's dead either with the roomba or the charging station or power supply. Does it charge up if you plug the power supply directly into the roomba, instead of into the charging station? If not, you'll probably have to return it to the place you bought it.
Aug 27, 2010 | iRobot Roomba 560 Robotic Vacuum
My roomba was not used for a month. Now it does
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Nov 29, 2009 | iRobot Roomba 560 Robotic Vacuum
New Roomba 560 beep twice, ask to clean brushes, but no dirt
your roomba is thinking that you need to clean the brushes. if too much load it put on your brush motor--the unit will think that something is wrapped around the brush and slowing down the motor. if you have cleaned your brush and are sure that is not the problem; you need to look for anything else that could be slowing down the brush/motor. If this is inconclusive you need to put your roomba into diagnostic mode by following the procedures in the link below http://swiftracer.com/index.php?myPage=RoombaDiagnosticMode.php
Jun 13, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba 560, the small red light above the schedule button will not reset and the roomba will not run. The problem started when I the roomba sat dead for 12 hours. I tried the spot dock reset trick with no...
You should start by removing the "belly plate" of the Roomba and simply removing the battery to cycle power to the unit. If that does not solve the problem, it sounds like you need a replacement circuit board for the 560. That's alot trickier since iRobot doesn't like to sell those...they want you to send to them for service.
Your options would be to send to a reputable Roomba repair center like www.protechrobotics.com or you can buy a replacement PCA from places like www.RoboticVacParts.com and replace yourself.
May 07, 2009 | iRobot Roomba 560 Robotic Vacuum
Wont charge
did you try plugging in 560 driectly to charger then run it?
Dec 26, 2008 | iRobot Roomba 560 Robotic Vacuum
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
