Question about Desa International Desa Heating Products Horizontal Square Termination Kit
I push in pilot switch, hit ignite and pilot will burn, but will not stay lite when let go after several minutes
  • cncfixxer May 11, 2010
    It's probably caused by a defective Thermocouple. It's less than $10 at Graingers (they are everywhere) but you may need help to change it. Remove it so you know the exact part size ... some are longer than others. Use a charcoal lighter when trying to light a pilot because they are long it makes life easy
  • 194 Answers
Three likely possisilities - one is insufficient gas pressure, another is a plugged pilot gas line and the other is that the thermocouple is defective. There are other possible problems, of course, but these are the most likely.
Posted on Oct 08, 2009
Pilot stays lite but burner won't ignite
you have either an open safety, poor wiring connection, or problem with tstat controls
Apr 15, 2014 | Zodiac Jandy Legacy LRZ 175K Commercial...
GAS WATER HEATER PILOT WILL NOT LIT
assuming you mean you have electric ignition, DO NOT try to lite with a flame of any kind. make sure gas is on, while pushing knob turn to PILOT hold knob down for appr. 10 seconds while still holding knob down,push ignter. you may have to do this proccess afew times. if this doesnt work, call a pro. gas appl. can be extremily dangerous
Dec 21, 2012 | Water Heaters
Igniter on my electrnic gas hot water heater does not work but tests good .so what can the problem be
Not enough information but I will try and guess. Assuming that you have a pilot. Set the thermostat to vacation mode. turn the gas valve knob to pilot and push down and then click the pizzo button several times to lite the pilot. You can look through the sight glass at the bottom of the water heater to see if the pilot is lite. If it didn't wait a few minutes and try again and look at the pilot and see if you can see a spark. If it did lite and then when you took pressure off of the knob and if went out you could have a bad thermocouple or a bad gas valve.....hope this helped.
Jan 31, 2011 | Heating & Cooling
Polite will stay lite but when you turn it on it will only stay on for a 10 ti 15 minutes and shuts off
Check to see if the pilot flame is hit the themcouple bulb. there is a angle sheild that mount be hind the pilot lite to keep main flame from pulling the Flame up and way from pilot lite and the bulb. If can't find one E-mail me And I will sent you one. Ken's Repair
Jan 18, 2011 | Vanguard International Blue Flame - Large...
I replaced the ignition transformer in my Teledyne Laars epc325 pool heater and cleaned everything. When I switch the heater on the burners all work fine but they only cycle on for about 10 seconds then...
This is probally your ignition wire is bad and not reading flame at the pilot or your pilot is bent or something so that when the pilot lights the flame isn't hitting the sensor probe at the pilot. When looking under the heater use a mirror so if you get roll out of the flame you don't get burned. Good luck and be careful.
Feb 26, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
Jandy Lite 2 - Pilot goes out when I turn to On
Sounds like you need a new thermo couple. found at most hardware stores
Jun 23, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Lighting the pool heater
You will need to buy a new thermo couple 8.00 part from ace it is the little copper line close to piolet flame,it sences the piolet and allows the gas to open and feed,it is wore out,burned out,replace.
Mar 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot lite will not stay lite
You need to change the thermocouple on the unit.
First check to see if the flame is hitting the thermocouple when the flame is on when you hold down the button. If it is then remove the the thermocouple and replace with the same size. You should be able to pick one up at your local hardware store.
If when you replace the thermocouple the flame does not stay lit still you may have a bad gas valve.
Hope this helps and please rate this!
Dec 08, 2008 | Honeywell Electronic Programmable...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Desa International Desa Heating Products Horizontal Square Termination Kit Logo
51 people viewed this question
Top Desa International Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Desa International Measuring Tool and Sensor Expert? Answer questions, earn points and help others
