Question about Frigidaire GLWS1649A Top Load Washer
Washing machine GLWS1649ASO wont spin on spin cycle. motor and pulley turn, but belt doesn't move. Is it the belt?
  • Anonymous Mar 16, 2014
    washing machine wont spin
  • 1,531 Answers
No it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Posted on Oct 02, 2009
Admiral washer will not spin but does agitate.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely -if it's frozen or stiff- replace it.
a.- It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
a.1. If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
a.2. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.- It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
b.1. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.2 The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
b.3 A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
b.4 The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
b.5 The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
b.6 The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
b.7 The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
c.- It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up
Additional details in Admiral: Washer Use and Care Guide (PDF Format)
Check it and keep us updated.
Oct 10, 2011 | Admiral AW22 Top Load Washer
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
My Defy 600 does not drain all the water out and wont s apin. When I try to start a new cycle it wont let any water in, i suspect thats cause there is still water in the drum. Help!!!!!
hello there and welcome to fixya
Aug 23, 2011 | Washing Machines
My washer wont spin
Hello there and thank you for choosing fixya
This can be a rather easy fix or it can be a nightmare so i will post everything i have here for you to check ok
It doesn't spin It doesn't pump or spin
Aug 05, 2011 | Kenmore 24032\24036 Top Load Washer
On spin cycle drum going round but not spinning so clothes stay wet
Hi, if it doesn't spin, check to see if the motor is running, then proceed as follows:
Jun 20, 2011 | AEG Lavamat 74640 Front Load Washer
Washing machine wont spin in spin cycle ,makes spinning sound just wont spin
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 01, 2010 | Washing Machines
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Clothes are still soaking wet after spin cycle and the wash cycle is complete.
If the drum spins in the spin cycle, then the belt can't be broken. However, if the drum does not move at all in wash and spin, then the belt can be broken or just fallen off. You will have to remove the back plate and fit the belt back on the drum pulley and the motor pulley. If belt is ok check the motor brushes, they could be worn. They are located one on either side of the motor and identifiable by a single wire that connects to each one. You could also have a restriction in one of the drain hoses which is not allowing all the water to drain out.
Nov 05, 2007 | Maytag MAH6500 Neptune Front Loading...
Washing machine belt won't move
You probably have bad spin tube bearings. Look above transmission for a water leak or evidence of one.
May 27, 2007 | Kenmore 94812 Top Load Stacked Washer /...
The machine won't wash or spin... Motor pulley?
take a look at the transmission if it has a whie tag or label bad transmision
Aug 12, 2006 | GE WVSR1060A Top Load Washer
Frigidaire GLWS1649A Top Load Washer Logo
213 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
