Whirlpool Heavy Duty Commercial Washer -appears that a previous user remover their clothes with 9 minutes left in wash cycle-will not complete that wash cycle, or start a new wash cycle- machine is coin-operated, and have put in the $1.25 for another wash cycle- tried removing/replacing plug, but no luck
  • 25 Answers
Perhaps the reason someone removed the clothes early is the washer quit working on them ... you merely tried to use a broken washer
Posted on Oct 02, 2009
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
How do i find out whats wrong with my washing machine? The brand is whirlpool heavy duty
check for a clogged filter screen on the cold side of the water inlet valve,the cold water shut off, or the hose kinked
good luck
Feb 28, 2013 | Whirlpool Clothes Washer Heavy Duty...
How do i replace the agitator in my old heavy duty whirlpool washing machone?
Hello.
The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
Thanks.
Sep 07, 2011 | Whirlpool Washing Machines
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Feb 21, 2010 | Washing Machines
Whirlpool Calypso stops at 26 minutes and throws ob code
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Dark dirty spots on some clothing items appears on every load.
what you are seeing is suds getting back onto the clothes. make sure you are using HE type soap and not using too much of it.
if you are seeing suds inside the unit, when it is running, then it will "re-deposite" dirty soap residues back onto the clothes.
you need to run a rinse and spin cycle or even a heavy duty cycle with hot water to rinse out any soap that is left in the unit.
not a major problem, just use it differently and it will be ok.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer problem
turn the water supply on,, f/h is a fault occurring when ther is no incomig waterdetected
Apr 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
