Question about Brother MFC 420CN All-In-One InkJet Printer
Olny blue and black ink can work
Only blue and black ink works resulting in a bluish colored picture for all the colors needed.
Mix-it-up
  • 832 Answers
SOURCE: Black ink not working; but colors are
Use a original brother ink cart. Do the cleaning twice. If there is no more black blocks to see, the printhead is crashed!
Posted on Sep 11, 2007
gwbm
  • 353 Answers
SOURCE: The new ink cartridge is not dispensing its color.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If these actions produce no positive results, or if you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer
on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way.
Look inside the print head parking area on the right and you will see a rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. Repeat this process again if necessary.
If still nothing, it looks like you may have a failed cyan print nozzle I'm afraid, or some other internal problem. This will require checkout by a Technician. Make sure you compare the cost of repair with the cost of a new printer!
Posted on Feb 28, 2009
  • 214 Answers
SOURCE: I have an HP 6180 that works fine except the
Bugger! HP wants your printer to work, so you buy more ink! Mine works beautiful
Scan a good photo and print it out or insert SD card and print photo on PHOTO paper GLOSSY SIDE DOWN Inkypete
Posted on Apr 21, 2009
  • 24 Answers
SOURCE: Can't use black cartridge only to print
Unfortunately it is all true.
Personally I would stay away from Lexmark, I am a Canon fan, the MP520 looks real nice, but it's personal choice at the end of the day.
Posted on May 29, 2009
  • 526 Answers
SOURCE: will no print black color doc if any other color ink is empty
actually, its not. the reason is, there is a small resovoire (sp?) in the ink cartridges. if you continue to print, the nozzles will clog up, and can cause all the nozzles not to work. even when you do just black, the printer has to clean at times all the nozzles and if your nozzles are empty, air will go into the deep and dry up the excess ink.
if you are going to do primarily black prints, you should get a black and white laser for those uses only.
Posted on Jun 19, 2009
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
Bluish color to copied photos
Replace color cartridge:Reason: Color cartridge carries three color for color combination, in that any one of color empty or dried up color combination wont happen perfectly, result printer get mismatch colors.. In your case it might be magenta color over.. replace color cartridge to get good print outs..
Jan 31, 2012 | HP LaserJet 3050 All-In-One Printer
Color mismatch
This is kind of hard to diagnose with just what you list. However there are a few things you can do to test it further.
What I usually do is open up Microsoft paint (start-all programs-accessories- the click on paint)
Then make a small box and print the 3 primary colors plus black (red, blue, yellow) see if all three colors print. My guess is only one will print (blue) if this is the case then the ink cartridge is most likely dried up or defective. Also if you have not printed something in a very long time this can also cause the cartridge to dry up. Again this is based on a guess that I think your cartridge might be dried up. However it can be a number of other items.
Also some printers have there own test pages you can run that can also tell you what colors are working and what colors are not.
Thanks again
Hope this helps you out a little bit.
Steven.
Apr 21, 2010 | Brother MFC-5840CN All-In-One InkJet...
Bluish color right coener
I'm afraid, it is problem of optics unit block (light engine), there are 3 LCDs red-green-blue for color picture formation and blue LCD sounds bad, please call local TV tech for fix.
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hpdeskjet932c quit printing yellow & blue
Just try with replacing the color cartridges may be it is dry.
Sep 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Pictures coming out green
On a picture that you have printed, when you see an area of green, what color should it be? You probably have reduced flow of one of the "balancing" colors. Blue, Yellow and Red add up to Black. If your picture is supposed to be almost black and you don't have enough red, the color will pull toward the blue and yellow, giving it a green tint.
Aug 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I have an HP 6180 that works fine except the colors are WAY off -- everything is muted and dull and the blacks are very weak. I've tried everything in the print dialogue box -- switching to application...
Apr 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
My priter prints blue lines across all colored pictures or text.Any Idea?When printing black only,there is no problem.any colored - blue lines are added.I did reintal the drivers,used old and new but...
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
Jul 03, 2008 | Lexmark X5150 All-In-One InkJet Printer
BLUE tint instead of black
This is an indication that the blue gun is being driven too hard. Have you tried to adjust the blue color control? If not try this first and if the control can not adjust the color then you will have to find out if the control grid on the blue tube is working and has the proper voltages present. Which you will need the following equipment to do. Multimeter Oscilloscope Along with these you will need a schematic to show you what the signals and voltages should be. And I might also suggest having a pattern generator and using the color bar signal since more then likely that is the one being used in the schematic as the reference signal.
Oct 04, 2007 | JVC AV-56P575 56" Rear Projection...
Brother MFC 420CN All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
