Question about HP Officejet 5510 All-In-One Thermal Printer
I get a message that says Print Cartridge error see the product document for details.
BARRET
  • 21 Answers
SOURCE: cartridge error
Hi, As you are receiving cartridge error you can try to check if the cartridge ink levels is fine or take out the cartridges and check for the cartridge expiry dates printed on the cartridges as the cartrige error only occures if there print cartriges are expired.. However you can try the instructions in the below HP webpage to isolate the issue http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-45265-1&cc=us&lc=en&dlc=en&product=390315&dlc=en&lang=en Just click on the weblink to open the HP webpage and follow the instructions if the issue is still unresolved check the issue with another set of cartridges too this should fix the issue Regards, Barret.
Posted on Sep 27, 2007
SOURCE: hp officejet 5510 all in one cartridge error
There are several different ways I've come across which will resolve ink cartridge errors on the HP Officejet 5510.
HP's standard, pat answer to the problem is "Buy brand new genuine HP ink cartridges." If you refill your own ink cartridge or have it done at Walmart or somewhere else, you will eventually run into this problem. Why? Because the 5510 stores information on as many as 2 of the black ink & 2 of the color ink cartridges you have used in the machine - complete with an "expiration" date for each of those cartridges. You can refill them, but unless you clear the stored memory in the printer you probably won't be able to get around the errors. Even if you do, they usually come back in a short period of time. I know this because I own a 5510 & a 5110 and have battled this problem myself for a couple of years.
Short of buying "genuine new HP ink cartridges", using your printer for target practice, or testing it's aerodynamic design... lofting it not-so-gently from a 2nd-story (or higher) window... aiming for the nearest dumpster ;) you might try:
  • http://www.misterinkjet.com/hpreset.htm Scroll down and you will find links to pages for the #56 & #57 cartridge serial number reset procedure.
  • If the above doesn't resolve your problem, try removing both cartridges, then - with the printer still turned "ON", unplug the power supply cord from the back of the machine. After one minute has passed, press down and hold both the "#" button and the "6" button on the keypad and while pressing those buttons, reach back and plug the power cord back into the machine. The LED readout will indicate "Initializing" and "Reset..." Then, release the "#" and "6" buttons and wait until the machine re-initializes and prompts you to install ink cartridges. Reinstall the cartridges and see if the problem is resolved. The reset procedure, as well as other troubleshooting procedures (paper jams, ink cartridge jams, etc.) can be found here, on the HP support pages.
  • Another way of working around the cartridge error problem is to keep at least 3 sets of cartridges on hand, using the newest sets for re-filling. You may have to switch out 2 or 3 times just to get the machine's memory maxed out, but the third set should work. This particular method works best with OEM HP cartridges, but I've heard it works with other brands, too.
For more adventurous-techie-types, who can't resist tearing into the machine in an effort to resolve the cartridge error permanently, I found the following information posted on a DIY (Do It Yourself) repair forum:
The 5510 has a pair of 1.5v batteries which function much like the CMOS battery on the motherboard of your computer - they supply power to the memory chips which store the serial numbers and expiration dates of the last 2 sets of ink cartridges which were used. The batteries are sealed together at the top and bottom and are attached to a circut board inside the printer on the left-hand side. At a glance, they look a lot like a capacitor or something like that attached to the board. If you look closely, you will see the "+" and "-" markings.
Breaking the connection (located at the top) between these two batteries will clear the ink cartridge serial number info from the printer's memory - but be advised this will probably also clear other short-term memory items also - such as last number redial, etc.
The clever individual who posted this info actually attached wires - one to the top of each of the 1.5v batteries - and ran the wires out through the opening above the paper trays. The wire-ends are connected together - I imagine they would need to be held out of the way of the paper path with a piece of tape.
(M-I-C-K-E-Y...M-O-U-S-E) He, he
When it's time for a cartridge change/refill, the wires are disconnected to clear the memory, then reconnected again after the full cartridges have been installed.
I've read posts from people with different models of printers have mentioned installing a switch to clear the memory - a preferable solution than to have wires running out from the inside of your printer.
This is a widespread issue and regardless of how you resolve the error messages, one must always remember that when you bypass something that is built-into the design of an electronic device, you run the risk of damaging components. In this case, the biggest problem would be running too low or completely out of ink and burning out the print head on the ink cartridge; then you would end up having to replace the cartridge anyway.
Personally, I'm basically fed up with the way HP has been forcing people who buy their printers and All-In-Ones to pay outrageous prices for replacement cartridges, by building machines which generate error messages and reject refilled and non-OEM cartridges. Their drivers and software programs often have compatibility problems even with other HP products which are installed on the same computer with an HP printer. Too many problems for me - I won't be buying any more HP printers and I hear Dell is not much better.
While I haven't tried to jump out the memory on my 5510 yet, that will be my last and final effort before giving it the aerodynamics test... into the nearest dumpster!
Posted on Mar 17, 2008
rakeshpramod
  • 234 Answers
SOURCE: C4180
Plese try the steps in the bellow mentioned link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01091133&cc=us&lc=en&dlc=en&product=1141647
And always make sure we do not use refilled ink cartridges.
HP Printers are designed in such a way that it will not detect the refilled ink catridges or non-HP ink catridges, that is why HP if you guys know HP Generates its most of its Revenue by selling Cartridges, and also they are reliable, value for our money and trouble free thats because they are manufactured under six sigma quality.
Make sure to take out both the ink cartridges, unplug the power cable directly from All-In-One when there is still power in unit and unplug it also from the wall outlet, wait for atleast 1min, before reconnecting (but before reconnecting make sure to clean the metal contacts not the nozile where the ink comes out with a lint free cloth and little drinking water, only moistened and clean all the metal contacts with the same and make sure the contacts are not wet before inserting the cartidges back and do not touch the metal contacts) then insert the power cable directly to a wall outlet without a surg protector and then connect it back to the All-In-One and then allign.
Good Luck
Posted on Sep 03, 2008
SOURCE: Cartridge Error
We had a client come in today with an HP OfficeJet 4315 that they bought a couple weeks back at Office Depot. The carriage jammed up after installing a new black ink cartridge. He said he had received a “Cartridge Error” and a “Clear Carriage” error. We fixed the Cartridge error by removing and inserting the black ink cartridge back into place. The clear carriage error was just as easy. We powered off the printer, opened up the right side where the ink carriage was hiding and pushed the carriage to the left. We then just powered it back on and it performed an alignment test. That’s it!
Posted on Oct 24, 2008
  • 21 Answers
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd9
Posted on Sep 06, 2009
I am getting error message--Print cartridge in right stall not supported. I have cleaned the cartridge and still receive error message, Any ideas on how to remove this message?
Are you sure that the cartridge is the right cartridge for your printer?
here is a link that would eliminate possible causes why you are having that error message.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00427221&cc=us&lc=en&dlc=en&product=441240&tmp_track_link=ot_search
that should solve the problem.
Mar 06, 2011 | HP Photosmart 2575 All-In-One Printer,...
My 5500 all in one printer is flashing print
check if the cartridge is not empty or the nozzles of the cartridge is not blocked. if so replace the cartridge and then try to print
Apr 16, 2010 | Computers & Internet
When I turn my hp officejet 5510 all in one ink cartridge it says the print cartridge error see the product documentation for detail copy fax, scan are all blinking.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00837918&cc=us&lc=en&dlc=en&product=311255
When lights stop blinking, you have solved the problem.
Nov 28, 2009 | HP Officejet 5510 All-In-One Thermal...
Cartridge error -
FRIEND THIS PRINTER IS IN RIGHT SIDE next to LEVERS OF BLUE CARTRIDGE TWO SMALL LAMPS ARE sensors, if they are dirty TONER WILL MAKE OF THIS MESSAGE.
Jul 17, 2009 | OKI C5200n Laser Printer
Get an error message that says "Cartridge Error."
It could be an indication that it's reading the cartridge incorrectly or the cartridge isn't properly seated. Try re-inserting the old cartridge or a new one to correct your problem.
Jun 17, 2009 | Office Equipment & Supplies
Print cartridge error
hi..
try to install and reinstall the cartridge to the printer...
maybe there is a loss connection between the printer and cartridge..
and also clean the tab circuit of the cartridge..and the tab circuit printer carrier where the cartridge is installed....^_^
if the problem still exist try to replace the tanks of the cartridge maybe the tanks was not recognized by the printer...
May 12, 2009 | HP Officejet 5510xi Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
