Question about Food Mixers
Makes a thunking noise with every rotation. sounds like a gear is messed up somehow. The beater hesitates as it goes through its rotation.
  • 25 Answers
It probably is .. The most common cause is something got stuck in the beaters and some gear teeth got damaged.. They are very easy to replace but can be a little messy because of the grease on the gears. If you tell me your make and model I will tell you what parts you probably need
Posted on Oct 02, 2009
Beaters are hitting each other and jamming up
One of the beaters had jumped a gear. I understand they are nylon gears. My wife's had the same trouble. I unplugged the mixer, removed the bowl and install the beaters if you can to see where they are touching. They were two cogs off. I grapped the left (red) beater firmly and twisted it to the left. It took a couple tries and turning on the motor (with out beaters) to find the spot where they had skipped. In the end the left beater jumped back one then two teeth and now the beaters aline properly.
This will happen again with heavy dough, etc. now that the teeth are worn in that spot. Use a bread machine for the heaver dough. IMHO
Dec 12, 2012 | Sunbeam 2346 Heritage MixMaster Series...
Mixer makes a clicking noise and beater stops turning or mixing...gear seems to be slipping...
The only part that consistently wears out is the Worm Gear Follower located inside the Transmission housing. The teeth are wearing out and becoming chipped. The clicking noises you hear are made by the Worm Gear banging on the Follower. All the teeth of the Follower are now damaged and the Planetary stops rotating.
Removal and replacing of the Worm Gear Follower is no easy task. Let me know if you need help.
(Do not try to remove the Planetary assembly by forcing it with a screwdriver. That is not how it's done.)
Jan 23, 2011 | KitchenAid KP2671 Professional 6 Series...
The mixer turn table won't turn? Its only a year old?
Don't know a solution, because I am having the same damn problem.
I am very discouraged with this product.
It is a piece of ****.
I am thinking about taking it out back and shooting it with my 270 I bought.
That is the only solution I know.
Dec 03, 2010 | Sunbeam Heritage 2346 Stand Mixer
Kitchenaid mixer makes a lot of noise. The beater
Hi - I've been searching for general info on KitchenAid stand mixers and ran across this so I'm throwing my $.02 in... Since KA stand mixer bases are essentially made of cast metal parts, there is a very slim chance that there is a lateral misalignment (side-side) unless it got dropped...eek! Sounds like a head height adjustment issue. Check out this from KitchenAid Conversations:
http://forum.kitchenaid.com/forums/topic.asp?TOPIC_ID=3032
Good luck.
DZII
Jan 02, 2010 | KitchenAid KP2671 Professional 6 Series...
Motor runs, beater stopped rotating. Some gear sounds heard before it stopped. Beater will not turn at any speed setting.
drive gear or shear pin stripped. Common on this model. Return to repair centre. Expect to pay approx $150.00 to repair, sorry.
Sep 14, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Beater too low-will not lock
I would check the bottom of the beater blades to see if they are out of shape.,or is the base of the mixer raised somehow to cause this problem
Jul 27, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid mixer
take off the chrome ring around the rotator. remove the screws that were hiding under it. pull off the rotator and replace the "O" ring on the shaft.
Mar 08, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Professional 6 stops in every rotation
you will need to open it up and check it out. sounds like a broken gear. it's not difficult to work on just remember where everything goes so you can put them back. mendingshed.com has parts and you can find how to do it on kitchenaid.com
Oct 15, 2008 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid professional....
It sounds like you need to change the brushes. You can look up your parts manual online here and then buy them online. Should be under $10.
Aug 16, 2008 | KitchenAid KSM50PR Professional Series...
Food Mixers Logo
106 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
