Question about Ace Hardware Ace& Extractor Damaged Nut/Bolt Remover
Threads are damaged on a bolt.I've tried to rethread it with a die set tool,To get the nut back on,but it did'nt work.The bolt can't be changed.Any ideas please.
    President:
  • 1,714 Answers
Use a 'tap' on the nut too. Re thread the bolt again, make sure you have the right tap and die, it isn't metric is it?
Posted on Oct 03, 2009
How to replace the t-bolt on the clamp ring of my purex triton 4000 series?
The easy part is getting the old T-bolt out- just cut it. However, I think you will be hard pressed to find an exact replacement. You would have to be creative and come up with your own version of T-bolt, which is doable. I would go to a hardware store or Lowes/Home depot and scan out what they have in the hardware dept. that may work.
That being said, my first fix would be to try and rethread the rod and handle, maybe to a slightly smaller thread size. This would require a set of threading dies and taps. Maybe there's someone you know who has a set and can try the rethread fix.
Yes, the whole new rim part is like $177.00.
Jun 13, 2014 | PENTAIR KNOB-BAND ASSEMBLY - 17-4882
Thermostat housing bolts wont tighten up
Pull the housing off and check if the threads are stripped where the bolts screw in. On aluminum, threads can get easily stripped from over tightening. A shop can use tap and die tools to rethread the holes. It shouldn't cost too much.
Oct 21, 2013 | 2001 Dodge Dakota
Kohler cimarron broken seat, replacement parts don't work 2x's
No do not use metal bolt and nut as this can crack the toilet. Just go to Lowes or Home Depot and buy 2 plastic bolts , 2 plastic wing nuts, and 2 plastic washers. Install with seat through toilet holes and tighten by hand until tight. I then use pliers to tight just a turn tighter and the seat should be center as you tightened one side, then the other, and back again until tight.
Mar 17, 2013 | Kohler Cimarron Comfort Height 2-Piece 1.6...
Tension on my Pfaff Grandquilter
check carefully that the top thread is actually gong between the tension plates and not behind them and jamming on the retainer bolt
before threading the needle place the thread up to the point of threading the needle and pull on the thread , proper tension is when there is a slight resistance to pulling the thread
If it takes excessive force to pull the thread then it is caught around something so follow the thread all the way back to the spool to see where the problem is
May 21, 2017 | PfaFF Convertible Sewing Machines
The thread is tight and it jams
try adjusting the thread tension
check to see if the top thread has come off the thread take up lever--this can cause the machine to jam
change the needle----if the needle is the slightest bit damaged the cause the machine to jam---also the wrong needle for the fabric can cause problems also
try rethreading the machine incase the thread is caught somewhere
make sure the bobbin is in correctly & it's not warped
if you've already done all these things & it still jams up then it could be out of time & would have to be serviced by a repair shop with the correct tools to time it
Aug 29, 2011 | Singer 1120 Mechanical Sewing Machine
The wheelchair is a manual invacare ser num.07ae002124. Four upholstry scerws broke in half with one half still stuck in the frame of the chair. Do I have to drill them out or can I just replace the hole...
This problem happens quite often with the upholstery screws for manual wheelchairs. The threaded screw goes into a riv-nut captivated on the tubular frame. The riv-nut is applied with a rivet like tool. The screws usually break off or get stuck in the riv-nut.
The more difficult repair when this happens is with an expensive and not readily available tool to replace the riv-nut after is is drilled out of the frame.
The easier and less expensive method involves the following:
Spray a large amount of WD-40 on the broken screw. Using a small drill bit that is smaller than the screw, drill the screw into the riv-nut in the forward direction. The downward force while you are drilling with the WD 40 will do all the work. Do not try to back out the screw with an easy out or extractor (harder, more expensive, requires specialized tools, may damage the rivnut). This usually does not work and involves the difficult rivnut replacement described above. By drilling forward into the riv-nut the screw will advance forward into the frame and drop into the tube. ( No need to fish out the broken piece).
If the threads are damaged in the riv-nut use a sheet metal screw, if the threads are intact use a 10-32 threaded screw. ( If you have a 10-32 tap use it to repair the threads that are damaged)
If after all this work the broken screw does not cooperate, you can use a drill bit slightly larger than the screw to drill it out and use a sheet metal screw in its place.
With 4 screws to practice on you will be a pro by the second screw.
The additional disclaimer for this repair is as follows:
If you can't get it to work with any of these methods your final trick is to drill all the way through the top and bottom of the tube. Run a 10-32 bolt through the washer, upholstery, and both sides of the tube and thread a nut on the end. Hope this helps.
Feb 05, 2011 | Health & Beauty
Im replacing the water pump on my 1994 f350 with the 460 engine. I have one bolt on the pump that will not tighten. What do you suggest I try?
Bummer, your only option is to address why the bolt will not tighten, either the wrong bolt (too short) or stripped threads. If threads are stripped, use a helicoil to repair. Be certain to allow straight access as this step must be perfect or larger problems will result.
Oct 05, 2010 | 1994 Ford F350 Crew Cab
Stripped nut that is stuck on-- I was trying to fix my 1988 Buick Reatta problem on my own and I ended up screwing on a lock nut with the nylon insert too much and I thinked I stripped the nut because it...
The bolt is usually made is harder steel then the nut so you may get lucky and the only thing that will need to be replace is the Nut.
You can go and buy a Nut Splitter Tool or rent one from a Auto Parts store to remove your bad nut and replace it. Here is what the tool looks like and will most likely be the only thing you can use to removing the nut without damaging anything else.
Thank you for using Fixya and good luck.
http://www.northerntool.com/shop/tools/product_34573_34573
Aug 05, 2010 | Buick Reatta Cars & Trucks
How to replace wheelbearings and what tools i need
air tools nice- need to pull wheel, remove caliper out of way' pull rotor, remove large axle nut three torques bolts remove hub need to prees axle in block of wood large hammer works don't damage threads may want to have old nut partial install
Aug 11, 2009 | 1996 Pontiac Sunfire
Ace Hardware Ace& Extractor Damaged Nut/Bolt Remover  Logo
Top Ace Hardware Tools & Hardware - Others Experts
Are you an Ace Hardware Tool and Hardware - Other Expert? Answer questions, earn points and help others
