Question about Canon PIXMA iP1600 Printer
My printer won't recognize the generic cartridge I put to replace the emply PG 40 black cartridge does it have to be a canon
  • 544 Answers
SOURCE: Pg 40 and Cl 41 are too expensive
After you install the refilled cartridges and received the "you are out of ink" warning, press and hold the RESET button for about 5 seconds. Than a second time. The E-5 message should cleared.
Posted on Feb 22, 2009
mjc_co
SOURCE: can i use pg-40 cartridge in my printer
No, you can't. I have the same printer and tried to save a buck at Costco, where they sell a 41 and two 40's in bulk. However, the 40 wouldn't fit into the slot because the ridges are slightly different. Several online print websites list the 40 as being compatible, but it would fit on my iP6310D.
Take the 40 back and go somewhere that sells both the 41 and the 40.
Anyone who wants to buy 1 opened (but unused) and 1 unopened 40-ink cartridge, please email mjc_co@yahoo.com and I can either sell directly to you or put them on ebay. Thanks!
Posted on May 17, 2009
SOURCE: Printer not recognizing pg-50 cartridge
I had exactly the same problem. I called the Canon helpdesk and apparently the PG-50 is not compatible with the MP210. I then bought a new PG-40 which works fine.
Bit annoying as I have wasted £35 or so on the PG-50. This is also a bit misleading from Canon as the PG-50 fits into the MP210 perfectly, and when you are looking at it on the shelf it looks like a long-life version of the PG-40.
But there doesn't seem to be any way around it that I have found. Just bite the bullet, write it off to experience and buy a new PG-40.
Posted on Aug 18, 2009
  • 11800 Answers
SOURCE: the following cartridge cannot been recognized
There's something wrong with the connectors for the control chip on the cartridge - maybe they are dirty or bent out of shape. Or the chip itself is faulty. Or the cartridge isn't genuine (or was refilled) and the chip isn't recognized.
Posted on Dec 05, 2009
sabuv
  • 113 Answers
SOURCE: i own a canon iP1300
Can be a problem regarding the cartridge. What is the status of the color cartridge. Take a printout with the color cartridge alone. If no problem found get your PG40 cartridge replaced. One thing to be noted is that the printer always needs the color cartridge installed. Printer can work with color cartridge alone. But will not work without a color cartridge
Posted on Apr 09, 2011
How do I fix e07
I assume you have a Canon copier based on the E007 error code. The Fuser fixing film is torn and the Fixing film assembly or the entire fuser should be replaced. Very common issue.......You cannot reset that code without first replacing the part causing the code.
Dec 03, 2014 | Office Equipment & Supplies
I own a canon iP1300 printer and just bought a new canon pg- 40 black cartridge but its not being recognized by the printer, wat do i do
Apr 09, 2011 | Canon PIXMA iP1300 Printer
I have a Canon MP470, I had to replace the black ink cartridge, and after doing so, I got an error saying that the black ink cartridge is not recognized. I have done everything I know to do to correct...
Welcome to FixYa!
Check if the ink cartridge is compatible with your printer. There are only 2 models of Canon Black Ink that is compatible with MP470. PG-30 11ml and PG-40 16ml.
I hope this helps.
Thank you for using FixYa.
Jas247
Apr 07, 2011 | Canon Office Equipment & Supplies
Can i use pg-40 ink for my canon mp480
Sorry you can't use PG-40 on MP480. Canon MP480 printer takes only Canon PG-510 Black Ink Cartridge, Canon CL-511 Colour Ink Cartridge or Canon CL513 Colour Ink Cartridge (this one is high yield colour cartridge).
Feb 02, 2011 | Canon Pixma MP480 All-In-One InkJet...
My canon pixma iP 1800 does not recognise refilled colour cartridge. Can you suggest a fix?
  1. For the not-so-tech friendly, installing ink cartridges in printers can be messy and time-consuming. Although companies such as Canon are constantly trying to make designs more convenient for all users, there are still several tips that can help new printer owners install Canon PG-40 printer cartridges without mess or hassle.
  2. Compatibility
  3. Although many printer cartridges are specific to only a few models, the Canon PG-40 printer cartridge was designed for use with many models of the Canon Pixma and even some of the Canon fax machines. As of September 2010, the Canon PG-40 ink cartridge can be used with the Pixma iP1600 through iP1800 printers, the iP2600 printer, the MP140 through MP190 printers, the MP210 printer, the MP460 and 470 printers, the MX300 and MX310 printers and the JX200 and JX210P fax machines. This versatility allows users to stick with the same type of ink cartridge over the life of several printers and allows small business offices an opportunity to buy one type of cartridge for all office printing requirements.
  4. Refill
  5. Replacing printer cartridges can be expensive and, if it is possible, as it is with the Canon PG-40, refilling is a cheaper and more environmentally friendly option. Refill the PG-40 by gathering a 10 cubic centimeter syringe with a 1.5-inch needle, a pair of latex free gloves, an MIS Yellow Drill Tool, Scotch tape and black ink. Remove the label from the top of the cartridge and use the yellow drill tool to open the vent hole that was covered by the label. Next, load the syringe with 20 CCs of black ink and inject it into the ink hole (where ink leaves the cartridge for the page.) Make sure the needle reaches the bottom of the ink tank and then slowly inject the ink into the cartridge, stopping when the ink begins to well up at the needle insertion point. Now remove the needle and clean the top of the cartridge off to avoid color contamination. Put a small strip of Scotch tape over the vent hole and poke a small hole in the tape with a pin. Now reinsert the cartridge and run up to three cleaning cycles to calibrate the printer.
  6. Resetting the Ink Level
  7. While refilling ink in a PG-40 can save money, it can also cause difficulties when using the automatic ink level sensor. Reset this sensor by removing the cartridge after the printer has been calibrated and placing a thin strip of Scotch tape on the line of gold-colored leads nearest the ink hole on the bottom of the ink cartridge. Replace the cartridge and wait for the computer to display a warning about the ink cartridge being loaded incorrectly. Remove the cartridge and move the tape from the first to the second level of leads and replace the cartridge. When the PC displays a message that the cartridge is not recognized, remove the cartridge and replace without the tape. The ink level will be reset.
Jan 09, 2011 | Office Equipment & Supplies
The following cartridge cannot been recognized Black the printer use pg -40 plz help me.. my printer is ip 1880 is ther any solution if problem same when i replace the ink cartridge
Dec 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Apr 30, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Price of catridge of cannon ip1300
these are the cartridges used in 1300
CL-41 FINE Colour Cartridge
PG-40 FINE Black Cartridge
click here for cl 41 prices
http://www.google.com/products?q=cl-41
Click here for pg-40 prices
http://www.google.com/products?q=pg-40
Let me know if you need anything else.
Thanks,
Ekse
Mar 05, 2009 | Canon PIXMA iP1300 Printer
Do I have to install a color cartirdge (CL-41)?
Some will allow printing with just black & others will not. You may need to put a color cartridge in to print. Check your owners manual or canon website to make sure but if you do need a color cartridge you can buy a generic brand that works with your printer to save some $$. Hope this helps.
Feb 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Ink cartage
This printer will take either the PG-30 or PG-40 (larger size) cartridges for black ink, and either the CL-31 or CL-41 (larger size) cartridges for color ink.
Jul 26, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA iP1600 Printer Logo
135 people viewed this question
old marine
old marine
