Question about GE Refrigerators
5 year old GE side by side model GSS201E. Freezer
5 year old GE side by side model GSS201E. Freezer side emits a whistling sound, whether the door is open or closed. Sound is constant when compressor is running, but goes up and down in volume. Started couple of months ago. Also ice forms around the ice dispenser.
dididsaythat
  • 291 Answers
SOURCE: GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
Posted on Aug 21, 2007
SOURCE: GE Side by Side Model GSS22JERFWW
front of the unit with the door closed, what ever makes the ice come out the dispenser.
Posted on Apr 03, 2008
  • 115 Answers
SOURCE: Replace GE ice dispenser damper door on GE model PSI23sgna
take both hands and place on the front bottom edge of control panel pull up and out it is hard and you think you are going to break something but you are not when you get the control panel off there will be 4 screws at each corner undo them and slide that piece off then you can see your door
Posted on Dec 30, 2008
SOURCE: GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Posted on Apr 25, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
High pitch whistle after closing door
It is possible that the door gasket is defective
Jul 01, 2013 | Frigidaire FFU17M7HW 17 cu. ft. Manual...
What could be causing a whistling sound from this GE side-by-side refrigerator (5 years old) when the compressor is running? The whistle sounds like someone blowing into the top of a glass bottle.
fAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 14, 2011 | Refrigerators
GE model GSS22SGRBSS freeser fan slows down
Same problem and think this unit is a piece of JUNK. In 5 years of service i have had to replace the Water shut off Valve twice, and the heater located on the bottom of the freezer which helps to keep the freezer defrosted. The fan has a whistling sound constantly, within 2 days of putting something in the freezer it is full of ice. Sorry pal, but as I said this model is a piece of junk.
Mar 15, 2010 | GE Refrigerators
Whistling sound from inside freezer compartment
is this a loud whistling, like a dying bird stuck in your freezer, or is this a lower pitched, sort of gentle whistling sound. If its the former, you likely have a faulty freezer fan motor. replace
if its the latter, sounds like you may have a issue with the door damper, which allows the air flow from the freezer into the refrigerator. However, assuming you dont have any cooling problems, you didnt mention if you do, it may simply be a normal occurance, as some makes and models open and close this damper door automatically, and when it is closed, can sometimes cause a low whistling noise
Feb 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side Heating Up and Frost on Panel in Freezer
sounds like your defrost heater termanator switch,or defrost timer is bad-mike
Jan 22, 2010 | Refrigerators
Freezer unit makes whistling sound
This indicated obstruction of air flow. Is there a change in cooling temperatures also? Thanks, Sea Breeze
Mar 19, 2009 | GE GSS20IEP Side by Side Refrigerator
New High Pitch sound
If the sound is from the compressor, the unit is likely under warranty...generally 5 years.  If the unit is frozen up and the sound is from a fan that is hitting ice, defrost the unit completely.  Other fans in the unit could also be squealing.  You'll have to be a detective.
Nov 20, 2008 | GE GSS20IEP Side by Side Refrigerator
Not cooling!
check the rear of the freezer you may find a build up of ice there if so you have a defrost problem chances are the heater is bad you can unplug ref and let thaw or you can tear into the rear (pretty easy) and defrost with hair dryer and look at theheater which is a glass tube usual only one at the bottom of the coils but some models have two one in the center you will most likely find them bad if they are not chrome looking then they are bad replace defrost thermostat also this is common rule.let me know what you find god luck
Jan 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
