Question about Garden
Engine cover removal
I Need to tear it apart because I want to adjust the centrifugal clutch. how do you get the top grey engine cover off that covers the flywheel? the clutch is blocking access to the flywheel and inner clutch assembly.
  • 3422 Answers
SOURCE: Craftman weedacker
HI,
You need a long narrow 20T tork wrench to remove the clutch bell.Most stores that sell tools should have them. You stick the wrench down the opening of the clutch bell (where the shaft normally goes), hold the flywheel so it doesn't turn (a screwdriver will work) and then unscrew the screw that holds the clutch bell on.
Posted on Oct 04, 2008
SOURCE: weed whacker
I was unable to get that ring off also... I was able to pull plastic side apart far enough to pull motor out and "rewire" it. Even fit back in when I was done... just barely. and was very gentle...
I do not know how to get the ring apart, though.
Posted on May 12, 2009
panilling9
  • 284 Answers
SOURCE: starter pull cord
take a light and look into the clutch hole
you will either need a torx or star type nut driver or a allen or hex head nut driver to fit in the hole and turn the screw ccw while holding the flywheel.
Make note where all comes off and all goes back in reverse when fixed.also after you remove the clutch housing you will be stareing at the clutch shoes next and it will have markings on which way to turn it for removal.
Posted on Jun 01, 2009
SOURCE: how to remove(unscrew?) centrifugal clutch
Remove spark plug and insert some cord into the spark plug hole to freeze the crank shaft. This way you can unscrew the clutch from the engine .
Posted on Jun 23, 2009
bbreton
  • 437 Answers
SOURCE: Need to change pull rope on Poulan Pro Weedeater
sounds like you are trying to remove the drum assembly; try a torx driver or a phillips screwdriver. There is a srew that hold that drum on and the bolt is in that black hole.
Posted on Sep 29, 2009
Testimonial: "read suggetions & took another look. Found a small flat blade screw driver would work. Appreciate the help"
Getting to timing chain without tearing down engine 2000 dodge intrepid
I assume you're talking about the 2.7L V6. As you're probably aware (having had it apart before), the timing is properly set by aligning the colored links on the primary timing chain with the marks on the crank sprocket and cam sprockets. The only way I know of to see all these at the same time is to remove the timing cover, and you have to tear the engine apart to remove the timing cover.
Oct 29, 2016 | Dodge Cars & Trucks
How to adjust clutch inside primary case?
Because the clutch cable adjuster clearance increases with engine temperature, adjust
the clutch when the engine is cold. If the clutch is adjusted when the engine is hot, insufficient pushrod clearance can cause the clutch to slip.
1. Remove the clutch mechanism inspection cover and
quad ring
2. Remove the clamp and slide the rubber boot off the clutch in-line cable adjuster.
3. Loosen the adjuster locknut and turn the adjuster to provide maximum cable slack.
4. Make sure the clutch cable seats squarely in its perch at the handlebar.
5. At the clutch mechanism, loosen the clutch adjusting screw locknut and turn the adjusting screw clockwise until it is lightly seated.
6. Squeeze the clutch lever three times to verify the clutch balls are seated in the ramp release mechanism located behind the transmission side cover.
7. Back out the adjusting screw counterclockwise 1/2 to 1 turn. Then hold the adjusting screw and tighten the locknut to 72-120 in.-lb.(8-14 N•m).
8. Once again, squeeze the clutch lever to its maximum limit three times to set the clutch ball and ramp release mechanism.
9. Check the free play as follows:
a. At the in-line cable adjuster, turn the adjuster away from the locknut until slack is eliminated at the clutch hand lever.
b. Pull the clutch cable sheath away from the clutch lever, then turn the clutch cable adjuster to obtain the clearance gap
c. When the adjustment is correct, tighten the clutch in-line cable locknut and slide the rubber boot over the cable adjuster.
10. Install the clutch inspection cover quad ring onto the primary chain case cover.
11. Install the clutch inspection cover and tighten the screws to 84-108 in.-lb. (9.5-12 N•m).
Jul 23, 2014 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Primary chain hitting case on clutch housing, cable nearly fully adjusted clutch slips if adjust any more. bad grinding noise from chain hitting case can i adjust clutch any more in housing?
The primary chain adjustment has nothing to do with the clutch. Take the small upper inspection cover off the primary cover and use your finger to check the primary chain tension. It should have 3/8 to 1/2 inch up and down movement in the top run of the chain when the engine is cold. To adjust, loosen the lock nut on the primary chain adjuster on the bottom of the primary case. Turn the screw upward to tighten the chain, downward to loosen. Once set, tighten the locknut.
To adjust the clutch, loosen the clutch cable adjuster as much as you can. Remove the derby cover from the primary cover. Remove the spring and the locknut. Turn the adjuster screw counterclockwise as far as it will go. Turn it back in 1/4 turn and replace the lock nut and the spring. Replace derby cover. Adjust the clutch cable so that you have about a 1/8 inch play at the hand lever.
Good Luck
Steve
Apr 29, 2011 | 2005 Harley Davidson XL 1200 R Sporster...
Zx-9r 2000 how do you remove the clutch side cover to change the clutches
The clutch cover is removed in a two step process.
  • Remove the clutch cable by loosening the adjustment at top and bottom first. Then remove the cable end from the clutch lever. This should give enough slack to remove the cable at the bottom by the clutch cover. ** Take notice of the angle of the lever that the cable goes into the cover. You will want to re-assemble the clutch cover with that lever in the same angle.
  • Remove the clutch cover bolts around the outside of the cover.the cover should now be removed by pulling the cover straight out.
Thanks and I hope that this helps.
Steve
Jan 21, 2011 | kawasaki ZX-9R Motorcycles
Removing primary cover on 04 1200c
To remove the primary cover from you Sporty, you'll have to remove the shifter and foot peg. Then loosen the locknut for the primary chain adjuster and turn the adjuster downwards to loosen the primary chain. Then remove the plug at the bottom rear of the plug to drain the oil from the primary. Remove the clutch release mechanism cover from the outer primary. Remove the spring and locknut. Turn the clutch adjuster screw as far clockwise as you can turn it. Then remove all the bolts around the outside of the cover. While pulling the outer cover gently away from the engine, turn the clutch adjuster screw clockwise until the cover comes off.
Good Luck
Steve
Dec 18, 2010 | 2004 Harley Davidson XL 1200 C Sportster...
HANGS BETWEEN GEARS, MANIPULATE THE SHIFTER UP AND
Sounds like you have some shifter pawl problems. If you remove your outer primary cover, you can see the shifter pawl just behind your clutch assembly. The problem could be the shifter pawls, the springs, or the carrier. You'll just have to go in there to find out exactly what it is.
To get the outer cover off, first loosen the primary chain tensioner beneath the primary cover. Then remove the large round cover from the outer primary cover. Beneath the cover is a spring with a locknut over the clutch adjuster. Drain the oil out of the primary and remove all the bolts around the primary including the left side foot rest and the nut at the front. Slide the outer primary cover off as you turn the clutch adjuster clockwise.
With cover off, you may can see the problem with the shifter pawl but I'm afraid that you're going to have to pull the engine drive sprocket and the clutch assembly off to repair it. To do this, you need an air wrench to remove the front sprocket nut and the clutch assembly nut. The clutch assembly nut is left handed threads. Take the snap ring out of the center of the clutch assembly and remove the clutch adjuster plate.
When reassembling the primary, torque the engine nut to 150-165 Foot pounds, the clutch nut torque is 70-80 foot pounds left handed, adjust the primary chain to 3/8 to 1/2" up and down with the engine cold. Check the primary chain adjustment thorough the upper inspection hole on the outer primary cover. I highly suggest you purchase a service manual to refer to if you decide to do this job. If you do it yourself, the book will pay for itself with this one job. Otherwise, this is a pretty advanced job and you might be better off taking to an experience mechanic.
Apr 01, 2010 | 2003 Harley Davidson XL 1200 S Sportster...
I have an IBM Selectric III that has been stored for a couple of years. Before storage it worked fine, but now it just idles when powered up and nothing operates. I assume this means it needs lubrication....
Typically a machine that has been out of use, but was previously working may just need some lubrication on the motor centrifugal clutch assembly, but the entire machine probably would need lubrication also. You can first try to hand cycle the machine by grabbing the shaft that the carrier travels on and rotating it towards the (top to rear) rotation. This shaft rotates on revolution per print cycle and at rest the slot is slightly towards the rear of the machine. If you must lubricate the machine, then remove the cover. Lift the lid, place each hand of platen knobs and with thumbs, push down on release latches, after platen is out of machine, reach inside left and right cover and release the top cover latches and pull the cover straight UP to remove. Use 10 weight oil on motor bushings and centrifugal clutch hub (motor shaft).
Nov 08, 2009 | IBM Office Equipment & Supplies
Starter pull cord
Jun 01, 2009 | Troy Bilt Tb70ss Gas Trimmer
Clutch adjustment 2004 v-star 650
Sir,
The bike you are working on has a couple of way to adjust the clutch. Obviously the adjuster on the handlebars would be the first place but actually there is an adjustment on the other end of the cable that has a locking nut on it. You will need to loosen the nut that locks the cable and there should be another nut on the other side of the cable that you can tighten. As you tighten the nut it will take the free play out of the cable.
There is another adjustment on the inside of the clutch cover, it is on the clutch hub. The adjustment for this would be done by removing the clutch cover to access the clutch hub. On the outside of the hub there is an 12mm nut locking down a 6mm adjusting screw, the screw is adcually the first source of adjustment on initial assembly.
Let me give you the breakdown of how this works, your clutch mechanism has the hub adjustment, a ball, and a push rod that goes through the primary output shaft of the transmission. Then it goes to the actuating arm where your cable connects. The reason I'm telling you this is because often the ball in between the hub adjuster screw and the clutch push rod becomes welded to the push rod or it will actually start to come apart. When this happens your clutch adjustment goes away and you have no adjustment available through the cable or the clutch lever. Should this be your case I would recommend you take the clutch cover off, (be sure to drain the oil first), remove the six 10mm nuts securing the clutch hub, (this also holds the clutch springs in place), then you will have access to the push rod and the ball. You may have to tilt the bike over on the right side to get the push rod and ball to come out.
When you go to reassemble the clutch make sure all the adjusters are loose so you can adjust the clutch in the following sequence:
  1. Assemble the hub and secure the springs. You want to adjust the hub screw first. Gently turn the screw in until it contacts the ball, then back out the screw 1/4 turn. This prevents the ball from welding it's self to the ball and plunger.
  2. Install the clutch cover and the clutch cable all the way to the lever. You will first adjust the free play out at the base of the cable so you have maximum adjustment at the lever.
  3. Adjust the lever so you have 1/4 of free play at the lever.
This will give you a properly adjusted clutch that has lots of adjustment at both the handlebars and at the base of the cable.
Good Luck! This is a DIY job, you wont need to take the bike to the shop if you are able to do any routine maintenance. Should you have to remove the clutch cover you will need to replace the right side, (clutch cover), engine gasket. If you take it apart I would recommend replacing the ball if it has any signs or wear, it will be blotted, this is a very cheap item that can cause much grief.
Let me know if you need any further assistance.
Regards,
RSelvy
Jan 02, 2009 | 2004 Yamaha V Star Classic
Clutch cable's change
If this is the same as the RS125 cable i changed then the cable goes into the clutch cover engine casing yes? You do not have to take the whole engine apart you need to disconnect the cable from the lever and then you will have to take the clutch cover off. before you do this you will need to lean the bike on its side as you will lose the gearbox oil otherwise. plus the cluch will fall out as it is held in with dowels and not bolted (stupid design) once you have the cover off then you can disconnect the cable. if your gentle when taking the cover off then u will not have to replace the gasket however this rarely happens you will deffianly need to get a new gasket about 4quid. reconnect your new cable and then put the gasket on and be carefull wen putting the casing back on the engine making sure you do not damage the new gasket.
hope this helps.
Nov 10, 2008 | 2008 Aprilia RS 125
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
