Question about Tristar SB Steam Buggy Vacuum
I have a Steam Buggy and have not used it for years. It is full of hard deposits some white some blue. I have rinsed it out and the water is clear, but how do I stop this from happening in the future? Is there anything to clean it with?
  • 557 Answers
Those are mineral deposits. The way to help that is to only use distilled water in the unit.
Posted on Oct 02, 2009
Testimonial: "Thanks so much!!!"
Steam won't come out Shark steam mop
I found mine to to becaused by hard water deposits. Our tape water has all kinds of minerals in it. & after time the jets get plugged solid with white calcium scale. hard as a rock. Best solution is to disassemble & hone each jet hole. It dose take some time, but that will work. & for now on use distilled water or at least filtered is better than nothing. Hope this helps?
Apr 03, 2017 | Shark Vacuums
How do i clean off hard water deposits off the bar inside so that steam will come out again?
there are iron cleaning products available fro small goods retailers or repair shops that will break down those deposits
while it easy to fill from the tap , if you read the user manual it is recommended to use de-mineralised water for irons not tap water
Sep 13, 2017 | Scunci SS1000 Handheld Steam Cleaner
The mop just stopes making steam to the head. Could this be A heat coil problem? Also a lot of others have had This happen.
On these steam mops, you have to use distilled water, if you use tap water and do not have a house water softner or some kind of water filtration system, the water running thru the tubes of the steam mop
will develop calcium deposits, these deposits are caused by hard water and will clog up the tubes, and keep the mop from producing steam, then you will have to replace the lines. i own this brand of steam
mop and had the same problem you had, I replaced the lines and started using distilled water, and have not had any problems since and that was last year. good luck!
Aug 18, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a Steam Buggy Model No EK8005 that I haven't used for quite a while and I can't figure out how to get the cover open to put water in the well and I no longer have the user manual. Can...
You just have to turn the big black knob on the top of the steam buggy. If it is a little hard to turn, then use some pliers, which will do the job fine. As I had the same problem a few weeks ago.
Aug 13, 2011 | Tristar SB Steam Buggy Vacuum
How do I get a better spray out of the steam vac when using it for carpets - not the attachment hose? can I do some simple maintainence to clean it out for a better spray?
run clear water through the system after each use, as for your problem,, lime deposits build up when left idle and not rinsed, you can run any household lime remover through the unit with Hot water and you should be fine, check for build up at the ports where the spray comes out, and brush with a hard plastic brush
May 03, 2011 | Hoover Vacuums
Steam coming out but no water is being distribued for the steam to dry it
If you have used it a lot and you have hard water... the calcium deposits will clog the water dispenser. That's what happened to mine. I cleaned it out with white vinegar and it started working fine. It's simply something clogged in the water dispenser.
Zashiban
Jun 28, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark stopped steaming how to fix this
It may be mineral deposits. Empty reservoir of water, add 1/2 cup of CLR. Let sit 1 hour. Take mop outside with a mop head on but not the cloth padding. Plug it in and start pumping the handle to prime it. I used cardboard to do this on to cushion the mop and soak up moisture. Keep pumping handle until the mineral deposits clear and full steam is coming out. When I was done, I unplugged the mop, dumped out remaining CLR, and rinsed out mop reservoir with water. Please add fresh water, plug in and steam out rest of CLR out of tube leading to mop head. Otherwise your mop will still issue out CLR steam. As always, be careful to unplug and let the unit cool down before adding or removing CLR, water or mop head. Steam can cause serious burns.
Nov 21, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Heating up but not producing steam. Tank may be furred up as limescale deposits in water when tank emptied.
OK. This is an actual guaranteed solution to the Shark "No Steam" problem. The problem is well documented as hard water clogs the steam mops head. And using distilled water should prevent problem (not confirmed). But now that you have the problem, how do you unclog?
First off, Ive had two now. And my solution probably invalidates 1 year warranty, but I'm not interested in going through all the rigamarole of taking my mop back to the store. Maybe yours has expired or you want solution now like me.
This requires a drill. If you've tried the white vinegar route like me and it hasn't worked, and the toothpick, now it's time to get serious.
Remove the four screws. Then slide connection back and remove final two screws. Try blowing thru the small round hole at the end of the connector. If you can't blow through it, the smallest choke point near the hole is your problem.
Using the smallest drill bit in the standard drill set (not sure the size but it fits easily in the hole with room to spare) drill gently into the hole until it breaks thru the first resistance. Now blow through the hole. It should blow through easily now. Run some white vinegar thru to loosen up and remove other hard water deposits if you like.
Replace nozel. Replace two screws, Replace 4 screws. Done.
Use only bottled distilled water from now on would probably be a good idea.
In my opinion the problem is a design flaw built in by the Shark people. Appropriate name. Its called planned obsolescence. :( It breaks, you buy a new mop head (or entire mop if you can't find their part's website.)
Sep 13, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Steam doesn't come out anymore when I pull the trigger. I think the water in the tank is getting hot, but when I pull the trigger, only a little water comes out. No steam
Try putting some white vinegar in the tank to dissolve any hard water deposits. You should use only distilled water in this machine. Don't try to clean anything with the vinegar in it, but take it outside to run the vinegar through.
Aug 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Forgot how to use steam buggy. Need a manual. Model #8500
I would try here, they carry alot of hard to find manuals.
http://userguides.50webs.com/steam_buggy_ek8005_manual.htm
Jan 05, 2009 | Tristar SB Steam Buggy Vacuum
Tristar SB Steam Buggy Vacuum Logo
342 people viewed this question
Top Tristar Vacuums Experts
Chris Nomland
Chris Nomland
Charles T Nevin
Charles T Nevin
Are you a Tristar Vacuum Expert? Answer questions, earn points and help others
