Question about Mitsubishi WS-55711 55" Rear Projection Television
Mitsubishi WS-48511: can't adjust blue convergence
I see blue double image to the right, and I tried to adjust the blue convergence,the blue cross is way out to the right. Which parts might be bad?
  • 4 more comments
  • Anonymous Dec 24, 2007
    same problem on blue convergence
  • ykchu Dec 27, 2007
    Replacing STK393-110 IC fixed this problem! Thanks!
  • Anonymous Mar 30, 2008
    halo of blue missing from top of tv
  • wlz77 Mar 30, 2008
    missing blue in arch n top of tv
  • sixspreens Jul 12, 2008
    Same issue, but red gun.
  • DJRick Feb 13, 2009
    I have a convergence problem with a Mitsubishi TV WS-55411, I know I need to replace IC STK392-110, is there anything else I may need, I would like to find out, thanks. Mine is the Red!
  • 934 Answers
Replace R8c21 & R8c22 (3.9 Ohm 1 Watt) Ic8c00 Stk393-110 Mits. Part # 267p155010 (Use Sanyo Original)
Also Check F9a04 (5amp Pico Fuse) for open and replace if necessary.
Bill
Posted on Dec 21, 2007
It is having double image. The second image is to the right with red color.
Sounds like a convergence problem. See if you can adjust the customer convergence controls (in the menu).
If you can not adjust one or both the colors than your convergence amp is toast!
Mar 06, 2011 | Mitsubishi WS-65511 65" Rear Projection...
I am guessing that you did the convergence menu 1.CONVERGENCE MENU "MENU 2159, 4 FINE, 5 COARSE, 6 MISC
2. There are Fuses F9A04 & 05 that may be open.
3. If you do the self test do you come up with 2-2?
4. Self-test on threads here or at ctechnicians.com
5. If one or both fuses open you will need to change convergence amps and parts.(Kit)
Dec 23, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Tip
Mitsubishi WS-48511 Manual Download
Download Mitsubishi WS-48511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-48511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-48511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Reset Mitsubishi WS-48511 VChip Password
Bypass Mitsubishi WS-48511 Front Lock
on May 03, 2010 | Televison & Video
Tip
I hope that helps.
on May 03, 2010 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I have the mitsubishi 55711,i have a double image
This is a V-21 Chassis common, with these symptoms, for failure of the convergence amps. This set uses two STK 392-110 Sanyo amps mounted on a heat sink and hard to miss. They're a 40 pin ic about the size of a half pack of cigarettes.
It has also been my experience that two or more of the yoke return resistors need to be replaced, most commonly R8c21 and R8c22, both are 3.9 ohm 1w but test all of them for reliability.
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
May 14, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Replaced Convergence but pictures still display with double images
i went to converge my mitsubishi ws 73903 and the blue line wont go down to match the other ones
Oct 09, 2008 | Mitsubishi WS-73903 65" Rear Projection...
Mitsubishi platinum plus ws-55857
Solder connects = temporary fix.......Replace IC's..best
order two STK392-570 good quality.....16 to 22.00 each
...............................T.
Dec 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55711 55" Rear Projection Television Logo
827 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
