Question about Lexmark Wheelwriter 15 Series II Typewriter
Installed new ribbon. appears correctly installed.
Installed new ribbon. I am sure it is correctly installed. every third key stoke letter does not print on the paper, but it leaves an impression on the tape. the ribbon is advancing on the third key stoke. Could the problem b in the tape or the ball mechanism?
  • Lexmark Master
  • 3,594 Answers
There is probably a fold in the ribbon usually the bottom, reinstall it and be vsure it is flat between the guides.
DickyO
Posted on Oct 12, 2009
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com
Feb 27, 2013 | Brother SX-4000 Typewriter
For a Swintec 8014 typewriter: the bottom portion of the letters are not tranferring to the paper when the keys are striked. although the ribbon shows the full letter being striked, only the top portion...
Check to be sure the ribbon dosen't have a fold in it and is fully seated in place, be sure the platen is fully seated in the side frames, check the correction tape for proper imstallation it can rob the print if to high.
DickyO
Dec 03, 2010 | Swintec Office Equipment & Supplies
The correction feature is not working correctly. It attempts to lift the incorrect the symbol/letter, but fails. There seems to be plenty of correction tape and the ribbon seems to be on correctly ......
Be sure that the ribbon and L/O are fresh. If so be sure the L/o is installed with the dull side toward the paper and be sure the ribbons are correctable. (YELLOW OR ORANGE KNOB)
DickyO
Aug 12, 2010 | Olympia Startype 3 Typewriter
This machine gets used just a few times a year for straight typing. I was asked to replace the ribbon as the letters weren't appearing on the paper when the keys were pressed. No one knew when the last...
I'll assume this is an ibm ww. Just below the ribbon deck on the right is the ribbon feed motor try na little WD40 on the upper and lower bearings they do gum up also be sure the ribbon motor is plugged in.
DickyO
Oct 06, 2009 | IBM Office Equipment & Supplies
Only part of a letter appears when typed
You can try code I to increase the impression but probably the print solenoid is gummy or the plastic solenoid is broken. We sell the caps with installation instructions for 20.00 includes freight. DickyO Cleveland Business Machines 216-241-0027
Jun 15, 2009 | IBM Wheelwriter 30 Typewriter
Correction doesn't work
Hi:
Make sure that you are using a fresh correction tape, not one that has been sitting in a box for years. Also make sure that the correction tape is installed correctly and that the "sticky" side is facing the printed paper.
Good Luck
Andrew
Mar 08, 2009 | Brother GX-6750 Typewriter
Brother EM-530 corrective tape appears to be broken
Be sure the tape is installed with the dull side facing the platen. The tapes are readly available but be sure it is a dry L/O tape General ribbon T355 or equivlent.
DickyO
Jan 29, 2009 | Brother EM-530 Typewriter
Typing
Check to be sure that the correction tape is in properly and tight. Then make sure that the ribbon (and correction tape) are between the two metal "fingers" and the cardholder (which is the metal thing that holds the paper close to the platen right in front of the ribbon) Is the ribbon moving? You should be able to hold the ribbon up and see each letter on the ribbon. Also make sure the printhammer is locked forward. You should not be able to just reach in and take the printwheel out without the ribbon in place. The only other thing I can think of, is the ribbon got twisted some how. The dull side should be towards the paper.
Oct 07, 2008 | Brother SX-4000 Typewriter
Letters & numbers not printing correctly
The most common reason for this is something interfering with the printwheel. Turn off machine. Take out the ribbon, then pull back on the black lever to the right of the printhammer. This will tilt the printwheel towards you. Look to see if there is anything caught in the printwheel. Also check to see if the corr tape is installed properly. Corr. tape and ribbon should both be between the two metal fingers and the metal cardholder. Push the black lever forward and look to make sure the two metal fingers are not bent into the printwheel. If they are, simply push them forward and bend them so they don't. Re-install the ribbon, making sure it goes on the other side of the fingers. Turn machine back on and test machine. If it still doesn't work, you will need a trained technition to determine the problem.
Sep 18, 2008 | Brother GX-6750 Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
