Question about 2wire (1000-000057-000) Modem
Modem How do I decide which modem is right for my computer, for a dial up connection.
Dont really have a solution,but a few comments,am using a v92 modem,and has worked well,up until a couple of months ago,had ma bell out,shows 48kbps at the outlet,but only 21.6 an the puter,did have 45,300.Gotta USR brand,dont really know how to rid it of it's problems.But,If you have true dial up as some of us still do in rural areas,get someone knowledgable to set up your modem,dial up network,home page etc.
Posted on Aug 27, 2008
  • 138 Answers
Dial-up connection can handle 2 type of connections 1 is simple 56K modem and other is Broadband connection. 56k modems are mostly inbuilt modems and broadband connection is also inbuilt but it requires LAN connection i.e ethernet! RJ-45 Pin socket! If you computer supports LAN/Ethernet then you must use that connection which will be more faster.
Posted on Dec 22, 2007
  • 537 Answers
You want a 56K modem at least. Modems are becoming less common these days as brpadband (DSL/Cable/WiFi,etc) are becoming more cost effective.
Does your computer take PCI cards? If so, you might be able to find a PCI modem. There are also some serial modems still being sold. If your computer has 9 pin serial ports, you could try to use a serial modem. I think there also might be a USB modem that you could use, providing your PC has serial ports.
How can router, cable modem & Vonage modem be connected
Connect the Cable Modem - > The Vonage
Then Connect the Vonage -> The Yellow or Green Slot of the router
Connect your computer -> The Grey slot in the router
Run the Setup
Dec 11, 2010 | Belkin (F5D7231-4) Wireless Router
How can i use jasjam as a modem
Thank you for visiting Fixya Forums
Using a Jazjam as a modem:
• Before activating Wireless Modem, make sure your device has a
SIM card installed, and you have set up a GPRS or phone dial-up
modem connection on your device. For more information about
setting up a GPRS connection, see "To set up a GPRS connection to
the Internet". For more information about setting up a phone dial-up
connection, see "To set up a dial-up connection to your ISP".
Also make sure you have connected your device to a computer (via
infrared, USB or Bluetooth).
• When you activate Wireless Modem, ActiveSync will be disabled
To set up your device as an infrared or USB modem
1. On your device, tap Start > Programs > Wireless Modem.
2. In the Connection Type list, select how your device is connected
to the computer: IrDA if via infrared, or USB if through USB cable
3. To use your device as a GPRS modem, set the GPRS Access
point name. To do so, tap Menu > APN Setting and enter the
access point name.
4. Point your device at the infrared port of your notebook, or plug in
the USB cable adapter between your device and the notebook.
5. Tap Menu > Start.
6. The next thing to do is to add your device as an infrared or USB
modem onto your notebook.
To add your device as an infrared modem to your notebook
1. After you tap Menu > Start on the Wireless Modem screen
of your device, the Found New Hardware dialog box will then
appear on your notebook and will show that your device has been
detected as an infrared modem. In this dialog box, make sure that
Install the software automatically (Recommended) is selected
then click Next.
2. Wait for Windows to finish installing the infrared modem, then
click Finish.
3. You can now connect your computer to the Internet. Follow the
steps in “To dial up and connect to the Internet.”
To add your device as a USB modem to your computer
1. After you tap Menu > Start on the Wireless Modem screen of
your device, your computer will automatically detect that your
device has been connected. The Found New Hardware dialog
box will then appear on your computer.
2. In the Found New Hardware dialog box, select Install from a list
or specific location (Advanced) and click Next.
3. Select Search for the best drivers in these locations.
4. Insert the Getting Started Disc into your CD drive. Select the
Include this location in the search check box. Click Browse
and choose the CD drive and root folder where the modem driver
is located, then click Next.
5. Wait for the installation to complete, then click Finish.
6. Click Start > Settings > Control Panel.
7. Double-click Phone and Modem Options.
8. Click the Modems tab. Select the new modem from the Modem
list, then click OK.
Getting Connected
9. You can now connect your computer to the Internet. Follow the
Once the computer recognizes your device as a modem, you can now
use the computer to dial up and connect to the Internet.
1. On your computer, click Start > Settings > Control Panel.
2. Double-click Network Connections.
3. Click File > New Connection.
4. In the New Connection Wizard, click Next.
5. Click Connect to the Internet then click Next.
6. Select Set up my connection manually then click Next.
7. Select Connect using a dial-up modem then click Next.
8. Select the infrared, USB or Bluetooth modem that you previously
installed, then click Next.
9. Enter a descriptive name for this connection, then click Next.
10. If you are connecting to the Internet via GPRS, enter the
telephone number as *99#. Otherwise, enter your ISP‘s dial-up
phone number, then click Next.
11. Under Internet Account Information, you may not need to
enter a user name and password when using GPRS. Just click
Next to proceed.
12. Click Finish to exit the wizard.
13. The Connect dialog box then opens. Click Dial to dial up and
To end the modem session
• On the Wireless Modem screen, tap Done or tap Menu > Stop.
(Please give me a big thumbs up when you rate my answer, thanks.)
Jan 28, 2010 | i-mate JasJam Smartphone
Daughter gave me her computer. she had broadband, I have dial-up, can't get on-line.... no modem????
A lot of computers these days are supplied with no modem due to the popularity of Broadband.
To check if you have a modem on that computer do the following
Right click on "My Computer". Click "Properties". Select the "Hardware" Tab on the top. Then click "Device Manager". Go down the list until you see "Modems" and click the plus sign to expand it. If you see anything listed here you have a telephone modem installed.
If you want to stay on dial up and there is no modem in the list the only thing you can do is have one installed to the computer. However I cannot recommend this course of action. Dial up is a completely outdated and extremely expensive way of using the internet as you are charged each time the modem connects (like a telephone call). Even if you have a bundle of modem minutes from your provider it is still expensive and slow!!
Contact your provider and see if you can get Broadband in your area. You will not regret it - I guarantee you!
Thanks for using FixYa and please do rate my answer.
Nov 19, 2009 | Dell Dimension 4700C PC Desktop
My new pc Dell Inspiron desktop has no modem built in for dial-up internet connection. Im currently subscribing to a dial-up service provider on another pc, how do I connect to the same dial-up service...
You have to configure Internet Connections Sharing on the PC which has a dial-up service.
1. Click Start - Settings - Control Panel - Network Connections, right click on dial-up.
2. Clik on Properties, click on Advanced tab.
3. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box
After that you must connect the other pc to this one via network cable.
If you don'y have network adapters you have to buy them.
Sep 30, 2009 | Dell Inspiron 530s Desktop Computer...
New computer running slow
if you are using dial up, you shud not have a modem.. modem is just for DSL connection
if you have a modem probably you are using a DSL connection
dial up - connection using a phone line with internet connection; cannot use fone while on internet
DSL/modem- connection using a modem plugged in with computer and fone line; able to use fone even when on internet.
Jul 10, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
My modem with dial up but not high speed
You might need a new NIC card, thats high speed capable. What kind of hi speed are you trying to use ex.DSL,FiOS,Cable?
May 16, 2008 | Computers & Internet
Dial up modem cannot connect..
you need to download the right modem driver for your system. i have been trying to locate it for you but sadly, i cant read japanese
Apr 08, 2008 | HP Pavilion dv6000z Notebook
Belkin wireless router installation with a laptop that has an internal modem
Depending on the operating system that you are running, and if you have the appropriate wireless cards, you should be able to do this either with or without the modem. If you have the modem connected to one computer, and wireless cards on both computers, then your best option would be to just connect directly from one computer to the next. If you can tell me the answers to these few questions, I can help you get on the right path.
What operating system are you running? Windows XP? Vista? Macintosh?
Do both of your computers have wireless network cards? If not, then which computers have the wireless network, and which computer has the modem?
Feb 02, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Dial-up: Internet Connection
do your pc have a dial-up modem card?
What's the brand? Go to download the latest driver for the modem and try and see.
If not, right click on my computer icon, go to hardware tab, select "device manage", see does it detect any modem driver or not.
If after installing the driver still the same and can't be detected, most properly your modem is going to "heaven".....
Try to change another modem, see whether it can work or not.
Dec 14, 2007 | Computers & Internet
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
2wire (1000-000057-000) Modem Logo
171 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
