Question about Samsung Televison & Video
HDMI problem with XBox 360 and Samsung LE19R86BDX
My XBox 360 Arcade console will not work with my Samsung LE19R86BDX television using the HDMI cable - giving a ''Mode Not Supported'' message on the display. I have tried the same console and HDMI cable with another Samsung LE32R73BD television and it works fine. I have tried changing all the resolution settings on the XBox console and tried making changes to the LE19R86BDX television also with no success.
Does anyone know how to fix this problem?
Regards,
Paul M. from Newcastle
  • 192 Answers
SOURCE: HDMI Input Failed
I've been seeing alot of this out in the field. The cable is thick and heavy, after awhile the HDMI connectiion inside the set comes apart and breaks from the main board. In my opinion the only difference between Component jacks and HDMI inputs is the thought of reducing the amount of wire mass in the back of the unit. It's more pleasing to the eye. If it's under any kind of warranty, call a servicer. The main PCB will need to be replaced. If it's not under warranty, use component input cables, you'll get the same performance from your set and save a few bucks.
Posted on Dec 25, 2006
premtech
  • 934 Answers
SOURCE: YPbPr inputs not working
Tacz, What video input# on the back of the TV is your component video?? Are you sure the TV is set to look at that video input#??? You may be looking at one of the composite video inputs as far as the TV is concerned and with nothing plugged in to that input the TV would naturally give the error message you indicated. Let me know.. Bill
Posted on Jun 11, 2007
bernardlunda
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
SOURCE: "NOT SUPPORTED MODE" when using my xbox 360
If you got that while playing it sounds like its your GPU melting... when the older xbox360s get hot the circuit starts to warp and sag in the middle.. the causes the GPU to seperate from the board which gives you wierd or no graphics... ppl suggest "the towel trick" wrapping you xbox in a towel to overheat it in hopes it will reconnect the GPU.. otherwise there is very little you can do.. just hope MS will repair it for you or buy a new one.. i have the same problem at the moment with my friends old one.. so im currently working on a solution.. will try and let you guys know if i find something that works...
Posted on Jun 13, 2009
SOURCE: PC DVI to HDMI Regza Connection
I'm getting the same problem with an ATI Radeon HD 2400 going to a Regza AV555D on HDMI 1. In order to get the picture back I have to call up the source menu and move down to HDMI 2 (without clicking OK, just hover) and wait for the screen to change. Then go back to HDMI 1 for a few seconds until it flickers and then press OK. A bit long winded and far from a solution but it's enough to sync it all back together again
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
Mar 03, 2010 | Microsoft Xbox 360 Console
THERE IS NO VIDEO WHAT SO EVER
u may need another cable,do u have an arcade?if not try looking on the cable (HDMI)to see if it is set on HD or TV if u have an hd tv set the cable acorrdingly.
Nov 13, 2009 | Microsoft Xbox 360 Console
CONNECTING XBOX 360 TO SAMSUNG HOME CINEMA SYSTEM VIA OPTICAL
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
Jun 10, 2009 | Microsoft Xbox 360 Console
New xbox 360 arcade no screen or sound
to start off,what type of cable are you using??
since you've already tried using 2diff TVs,basically its with the console
try using a different AV CABLES, if it still doesnt work,try calling xbox support hotline for possible replacement of your cable or for processing a repair for the xbox if necessary..
since you just bought your console,try going back to the store where you bought it and have it replaced, because for the repalcement of the cable if you call xbox support,it will take 8-12business days for toureceive it and 2-3weeks for the turn around time of the repair for the xbox.
May 17, 2009 | Microsoft Xbox 360 Console
Samsung, xbox problem
Try to change the hdmi cable...
set your plasma hdmi input...
Good Luck
Dec 10, 2008 | Microsoft Xbox 360 Console
Xbox 360
The Arcade model comes with no harddrive, no hdmi (for digital connection to an HDTV), and I beleive the controller is wired instead of wireless. If you are planning on just playing games then the arcade may be a good choice for you as it's cheaper but you may find yourself wanting a hard drive sooner than later. Without a hard drive you will not be able to purchase or rent movies and you will not be able to download game demos and Xbox Live Arcade games. To compensate Microsoft includes a disc with some of the greatest hits of XBox Live Arcade with the Arcade version. The Pro comes with a 20GB hard drive but still no HDMI. The Elite version has a 120GB hard drive and HDMI. For most people the Pro is the one to get. If you were to get the Arcade then purchase a hard drive later you will pay more than the price of the pro.
Jul 07, 2008 | Microsoft Xbox 360 Console
XBOX 360 Elite HDMI problem
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Dec 25, 2007 | Microsoft Xbox 360 Console
XBOX 360/SAMSUNG PLASMA TV
If you have an Xbox 360 Elite or a newer Xbox 360 Premium, you should use an HDMI cable if your TV supports it. Otherwise use a component cable.
Nov 25, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
829 people viewed this question
Jerry Greenberg
Jerry Greenberg
