Question about Dell 1700n Laser Printer
Dell 1700 printer getting load|remove paper light blinking. Have removed tray removed paper put tray and paper back many times and it has not made a diffidence.Help
Printerguy
  • 31 Answers
SOURCE: Dell 1700 Printer
There is a sensor that is under the toner cartridge. make sure that it's sticking up. The fuser in the back of the printer has one sensor flag that is supposed to stick up all the time except when paper goes through it. What I see alot of times is that the sensor flags get stuck halfway down and all they usually need is a little help back up. Sometimes when removing a paper jam from the back of the printer the flag can be broken off, if that happens then your most likely looking at replacing the fuser. If you feel up to it you can take off the two side covers (the left one has a screw half way down in the front that you have to take out first) and then there are four screw on the back that take off the back cover so you can get a look at the fuser better. Remember to look for a screw that attaches the back cover directly to the fuser when you pull take it apart. Make sure there isn't any dust blocking the sensorts. Hope that helps.
Posted on Aug 23, 2007
SOURCE: dell 1700 laser printer wont load from tray only manual
If the rollers don't turn (or turn and slip) and maybe you hear a clicking noise from the left side of the printer, there is a spring clutch inside the gear at the end of the shaft going to the swing arm. I found that sometimes grease gets inside and causes the spring to slip instead of grip like it should. If you're very careful, you can take off the left side cover and lay the printer on its right side (left side facing up). Then remove 3 or 4 screws around the gear assembly and lift the assembly straight off the printer. To get to the spring clutch, you'll have to move a couple gears out of the way (remember how they go back or you're screwed - and watch the toner arm spring as well). Remove the plastic c-clip on the end of the pickup shaft and lift off the clutch gear. Pull the gear apart and wipe off any grease from the inner surfaces where the clutch spring sits. Reverse your steps to put it back together.
Posted on May 01, 2008
Corysf62
  • 188 Answers
SOURCE: dell 5200M laser printer
there is a flag in the output bin that lets the printer know when there is too much paper on top of the printer and it stops so that the papers do not continue to feed out and overflow.
Either the flag is stuck in the up position, in which case you can just gently move it so it is hanging straight down, or the flag has been broken off and no longer functional ( in which case the flag and/or sensor would need to be replaced).
Posted on Sep 28, 2008
SOURCE: Dell 1700
I've experienced this in the past and found a paper jam in the back feed roller and had to take the unit apart to retreave document. Try doing this (only if no longer under warranty) there are a few screws in the front and it should be able to come off easily.
Posted on Apr 02, 2009
  • 53 Answers
SOURCE: DELL Laser printer 1700/1700n
All flashing lights for the Dell 1700 series (1700, 1710, 1720 including those that have n or dn as part of the model) printers is a service related error. When double pressing the continue button twice quickly, the printer will give a secondary error code, narrowing down the printer part being effected. It is possible to even narrow the error code down even futher by double pressing the continue button and taking note of which combination of lights come on, wether they are steady or blinking. Most generally when this series of printers, when you get all flashing lights, something major is going on with the printer. It could be pointing to the fuser, or main board, etc. You can call dell warranty support and they will help narrow down which part is being effected. Most generally, what is being effected is not cost effective to get fixed if you are no longer under warranty.
Posted on Apr 27, 2009
Started out with paper, would start to load paper them as soon as paper stared in would stop. After several tries it would work. Then it stoped taking paper at all. Each time you try to print it stops and...
First I would remove the paper tray and check the rollers and print path for any scraps of paper that may be tripping up a sensor. If all seems well, ...
Try this next: It will reset the printer's configuration info.
To factory reset your Dell 1700 series printer follow these steps.
  1. Turn off your printer
  2. Open the front cover (push the button on the left side)
  3. Hold down the "Continue" and "Cancel" buttons and turn the power back on.
  4. When the "Error LED" light on the control panel is solid, close the cover and release the "Continue" and "Cancel" buttons.
Tip: To print a configuration sheet push the "Continue" button twice. This will give your printers IP Address.
Dec 31, 2010 | Dell 1700n Laser Printer
Tip
Dell 1700 1710 series printer. Paper not picking up trick....
Here's a quick tip. If your Dell 17XX series (not confirmed for newer than 1710dn printers) is no longer picking up paper from the tray, it MAY be from worn out rollers. Try this tip to get it going while you wait for a replacement roller to get to you:
1 - remove the paper tray
2 - remove toner
3 - flip printer upside down (exposing the rollers)
4 - remove the rubber on the roller
5 - invert it. (turn it inside out)
6 - replace rubber back onto roller (still inverted)
7 - test print.
If this doesn't work then the problem is likely a paper setting (set to legal or something) Good luck.
on Aug 27, 2010 | Office Equipment & Supplies
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
Who can fix my printer from paper jamming? It is a Dell Laser Printer 1700 and keeps jamin the paper. Who do I call? Have tried almost everything.We live in a remote Mountain area Colorado.
If you mean that the print cycle starts, but the "Paper Jam" lights up at the point where the paper starts to enter the drum, here's what I found worked.
The rollers that feed the paper come down onto the clean sheets on a plastic, spring-loaded arm Those rollers sometimes get too slick after a lot of use and they won't push the paper up and into the drum -- they slip like worn tires.
Solution: slip the rubber "tires"off the plastic roller "wheels" and reverse them, inside-out. Put them back on the wheels and the new rubber surface will probably push the paper just fine.
To do this you have to turn the machine upside down and remove the paper tray. I would unplug the unit and remove the drum as well before trying this.
Good luck.
Apr 16, 2009 | Dell 1700n Laser Printer
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
Sep 18, 2008 | Dell 1700n Laser Printer
Dell photo 924 all in one printer paper promblem
Unplug the power adapter from the printer and then remove the papers from the printer , open the printer cover and look for any obstructions , lift the printer and shake it firmly, turn the printer upside down and gently tab on it , roll the paper tray rollers manually , put back the power adapter and then try printing a document with only one paper in the paper tray if it still gives the same error then its an issue with the printer and if the printer is under warranty then get the printer replaced .. or purchase a new printer instead of getting it repaired .. dell is offering a new printer 926 for $49 with 1 year warranty.
Do lemme know if that helps.
Bye.
Jan 19, 2008 | Dell 924 All-in-One InkJet Printer
Dell 1700 Printer
Aug 23, 2007 | Samsung ML 1651N Laser Printer
Dell 1700n Laser Printer Logo
141 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
