Question about Sharper Image Air Purifiers
Broken "guitar string"
One of the "guitar strings" is burned in two, is this fixable?
It appears to have gotten hot, burned in two near the base.
  • 80 Answers
No. This is not repairable. You will need to purchase a new cell from your local hvac contractor.
Posted on Oct 04, 2009
Ionic breeze wire
I tried the guitar strings, they burned out quickly. The wires that came in the unit are not steel, they are not affected by a magnet. We suspect they may be tungsten or some other type of non ferrous wire. Until we find the right wire, we cannot repair them to last. Any assistance in locating the correct type of wire for use in ionizing air cleaners would be appreciated.
Jun 15, 2014 | Sharper Image Air Purifiers
Brush wheel not spinning
it can be belt or clutch failed. put the vac on its side and on the bottom there will be either two push clips or 2 screws remove them or push them and pull the bottom off. then when this is off you will see were the belt is for the spinning brush. if the belt is still on then the clutch has gone in the motor if the belt has gone take out the broken part and get a new belt, fitting new belt you need to remove the spinning brush it is either clipped in or slotted in , clipped is push the clips out to the side and lift the brush out, slotted it will just pull out. clean out the brush before putting back in also check the brushes bearing to make sure it moves easy as a failed bearing do to carpet string etc can burn the belt, any belt that has been burnt in this way should be removed and changed as it will damage the hover if still used after this part has been cleaned replace all parts and then turn on dont and it pluged in mains while you are doing this and dont use until it has all been fitted back..
Mar 26, 2014 | Kenmore Intuition Upright Bagged Vacuum...
String line broke
what is the model number as it could be anything, there are a few models made and some have more that other do, ion senor bars and diffusers etc it could be any of these.
Mar 24, 2014 | Air Purifiers
The string inside my ionic breeeze quadra is broken. Is it possible to fix it
Not so fast with the screwing part. Go to a music store, buy the G string wire(008)gauge- at least 41 inches long- for a guitar.
If you have a digital camera make a video/pics history of your dis-assembly steps.
Remove the ozone eliminator-by pulling it off the tower.
Start with the base 4 screws, followed by the 2 collar screws at the base.
NOTICE that there is a space between the two halves at the bottom. I paid NO attention to this space-boy did I ever try to snugly close that one before I looked at another one to see that this separation is there for a reason.
Next: remove the "TINY"12 screws - 6 on the front/back side of the units ribs-look for these.
Take pics of each step. You will be happy you did this.
Store all of these diff. screws in separate jars.
Open the unit now like a wallet. Notice that the sloped top control button/light module can now be removed. See those 2 black square plastic covers-they hide a spring and an upside down W shaped wire holder. The broken wire can now be removed. If you are lucky, you may be able to to twist your new wire-after pushing it through the cleaning bead -with the one going down to the bottom module. Mine was too brittle and broke apart as soon as I touched it.
Remember: The 2 wires you see are just one 41 inch long 008 gauge guitar string.
They thread through a signal contact bracket at the bottom of the unit that is activated by the breaking of the wire to turn the unit OFF. Getting to this bracket is somewhat difficult and requires patience. Take a lot of pics to be able to reassemble the S 1637. I pulled the 41 inch long string under this signal bracket, evened off the ends, moved the top module down 2 inches and twisted the ends around the W shaped bracket that compresses the spring.
Honestly, I had to adjust the spring two times because I left off the cleaning bead. Now just reverse the steps and you got your unit working. The new string seems to push a lot more air.
Before you replace all of the screws, fold the unit together, insert the blades , put 2 sets of veggy rubber bands around the top and bottom and plug in/turn it on. Mine works now better than new. Did I mention that I had to do 2. The second was done in 2 hours.
Good luck.
totrosko@yahoo.com
Mar 28, 2011 | Sharper Image Ionic Breeze® Quadra® 4.0...
I HAVE 2 IONIC BREEZE QUADRA. FIRST HAD PROBLEM WITH 1, NOW THE SECOND ONE HAS SAME PROBLEM. HAVE CLEANED AND DRIED THOROUGHLY THE BARS AND FILTER, AND CLEANED REST OF WIRES WITH BRUSH. WHEN I TURN ON I...
If none of the hi voltage grid wires have broken then check to be sure grid wires are truly cleaned.
If not cleaned in a while like every 2 weeks they will have carbon build on them. And from my experiences with cleaning them is the build looks similar to the color of the wire. Try some qtips dipped in alcohol or cotton balls. The build comes off like flaking metal. Also be very tender with these wires they break fairly easy. When done cleaning turn upside down and back so beads can scrape up and down on wires. Also you do know once clean the parts especially the big collection bars they need to dry for at leased 24 hours before ever powering unit back on. Hope this helps.
Dec 13, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
Living air xl 15 One of the two glass plates inside has broken along the edge of the mesh. "Adhesive" material that appears to hold the mesh in place is blackened as though burned. Fan will come on but...
Broken discharge plates have to be replaced, otherwise the high-voltage shorts-out through the break. The glue being burned is an additional clue.
The fan is a separate circuit/function.
Replace the glass plates (purchase from EcoQuest Intl. or from a EQI dealer near you, expect to pay ~$20-30/plate depending on model and shipping costs. I also sell them as I am an EcoQuest™ dealer, though the shipping charges may make me less economical than someone local to you. If you want my contact info, please respond with a "FixYa" rating - thanks in-advance.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Dec 10, 2009 | Alpine Air XL-15 Air Purifier
Broken "wire/filament' in ionic breeze quadra
This does NOT work. The electric guitar wires burn out in 1-2 months.
Jul 13, 2009 | Sharper Image Professional Plus Ionic...
Ionic breeze quadra
If you are talking about the 2 thin wires inside the unit, it can be fixed if you are good with taking things apart. You have to do an almost complete tear-down of all the internal components (many hidden screws). You can replace the broken wire with a .009 or .008 gauge E string for an electric guitar. This can be found at a local musical instrument store. The string must be cut to almost the exact length. The wire has a spring tension mount on a small circuit board. If the replacement wire is too long, there will be too much slack, too short and you will not be able to put it back together. I did this and it took me hours. I removed about 80 screws to disassemble it.
Nov 03, 2008 | Sharper Image Professional Plus Ionic...
Broken Wire
Go buy a couple of .09 guitar strings from your local music store. This is how I fixed mine. You need to very mindful of the way it is assembled whilst taking it apart so you can duplicate the assembly in reverse:)
Apr 29, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Unit seems stuck in the "drying grid" mode
I had the same problem with my GP. It has worked great for four years and only recently seemed to get stuck in this drying cycle. I cleaned the grid many times, cleaned the wires, cleaned the whole unit as much as I could to no avail. The trick: You need to clean the two metal prongs and surrounding area that insert into the bottom of the grid, when you inserrt the grid. they are sharp like nails, so take care. Use an alcohol based cleaners and clean the prong and around each base. This fixed the problem for me and she's back up and running well.
Aug 31, 2007 | Sharper Image Hybrid GP (SI724) Air...
Air Purifiers Logo
115 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
