Question about Frigidaire Dryers
Dryer makes a thumping noise when drum is turning its an electric fridgidare de5520rw2
  • Frigidaire Master
  • 7,482 Answers
Sounds like you have flat spots on your drum rollers.
If your machine is a front loader, remove the front of the machine, this will expose the belt and drum, remove the drum and belt, and this will expose the drum rollers.
Check the rollers to see if they have flat spots on them, if they do replace them with new ones. This should solve your thumping noise.
If the rollers do not have flat spots on them then you can try to lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil.
I hope this helps
Posted on Oct 03, 2009
The dryer is making a thump/thud noise as the drum turns. The dryer works fine but the noise sounds like something hitting everytime the drum goes around. Could this be the belt going out?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 02, 2011 | Kenmore 83142 Electric Dryer
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
Frigidaire LEQ215EE1 dryer making thumping noise
Posssibly have a bad drum roller if mechanically inclined you can do this yourself but you need to take the drum out to do this
Nov 15, 2009 | Dryers
I have a thumping noise as the dryer runs, but it seems to work fine.
Look closely at the seam of the dryer drum, at the very front and the very back. I suspect that the seam has developed a crack, and makes a thumping noise each time the crack passes over the drum support rollers. You will have to replace the drum to eliminate the problem
Jun 28, 2009 | LG DLE5977 Electric Dryer
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
Loud thumping noise
IT COULD BE THE DRUM BUT I WOULD INSPECT THE DRUM ROLLERS TO SEE IF ONE HAS A FLAT SPOT IN IT. IT MIGHT NOT HURT TO CHECK THE DRUM BAFFLES/PADDLES TO MAKE SURE THEY ARE TIGHT.
Jan 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Apr 04, 2008 | LG DLE2514 Electric Dryer
Dryers Logo
142 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
