Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer "squeels" occassionally during cycle - Maytag Atlantis MDE7400AY Electric Dryer
  • Maytag Master
  • 7,482 Answers
The noise you describe sounds to me like maybe you have a belt that is slipping when you are starting to dry your clothes. If this is so, then it may not be long before you will have to replace the belt because it will break, or burn in half.
Or you could have drum rollers that need lubrication.
If it is drum rollers and you have a front loading machine, you can remove the front of the machine, this will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Lubricate the drum rollers at the shaft with a good grade of machine oil such as 3 in One oil.
I hope this helps
Posted on Oct 03, 2009
Keeps filling up with water randomly during a cycle
Remember sometimes there is a rinse and soak that happens in some models, and if everything is running normal then all your getting is the occassional water release during certain cycles.
Aug 15, 2015 | Washing Machines
Dryer is squeeling through the cycle
Most of the time when this happens it is one of two things. The belt has gotten loose and is slipping, or the drum bearing is weak causing the drum to rub on parts of the housing.
Jan 23, 2013 | Maytag Dryers
MY LG DRYER DLE 5977W HAS A VERY LOUD (AND GETTING LOUDER BY THE DAY) SQUEELING NOISE AT THE BEGINNING OF EACH CYCLE. WITHIN A COUPLE OF MINUTES THE SQUEELING NOISE CEASES. ANY IDEAS ON HOW I MAY REMEDY...
your dryer drum wheels that support the drum are either stuck on their shaft or the shaft that they turn on are rusty or eroded out on the wheels/spindle and are creating the noise you hear,you need to access the drum and lower area to see these wheels there are 4 wheels 2 at the back of the drum and 2 at the front of the drum,the rear 2 are most likely the porblem,from the heat of the dryer element
Sep 06, 2012 | LG DLE5977 Electric Dryer
Squeeky dryer
belt is stretched from a worn bearing in the belts idler pulley
Replace the belt along with the pulley sold at most Sears stores
Jun 20, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Maytag Neptune Dryer MDE5500AYW beeping and resetting itself
Ok , I replaced the control board. Still beeps continuously. Just sitting there, nothing else is on, just plugged in......beeep,beeeep,beeeeep,WTF man? I am about to turn this damn thing into an anchor and invest in more clothes lines! Maytag sucks. MAYTAG an acronym for...
Maybe
All
Your
Technicians
Agree;
Garbage...
May 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
High pitch sound during rinse and spin cycle
makes loud squeel at end of spin cycle
Dec 27, 2007 | Washing Machines
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Maytag Atlantis MDE7400AY Electric Dryer Logo
54 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
