Question about Maxtor DiamondMax Plus 9 80 GB Hard Drive
It stopped working with no warning
Maxtor 80 GB in primary slave mode stopped working suddenly
20GB master works in another computer.
For Maxtor DiamondMax Plus 9 80 GB Hard Drive It stopped working with no warning. tried with cable select, but its not visible on my pc
Posted on May 02, 2010
    Scholar:
  • 89 Answers
Try switching the jumpers to cable select
Posted on Oct 02, 2009
I got this hard drive would like to have it as my slave but do not know what to set the jumpers at can you help me thank you steve Loveland
if you have existing hdd on your system.. set for Primary master and the second set to Secondary primary Master.or you can do the main hdd is primaray then the second hdd is default it will be automatic goes to secondary primary.
Jun 12, 2010 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
I have installed s new hard drive maxtor 80 GB, the original one
First please check the Master/Slave connector at the connector side of Hard disk and install the jumper to Master or cable slect and if problem persist then you should have to update the Bios
Mar 28, 2009 | Computers & Internet
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Maxtor One Touch III 320GB
THE PROBLEM IS MASTER AND SLAVE CONFIGURATION .. MAKE YOUR BACK UP HD A SLAVE IT MAY BE A MASTER NOW..
AND IF ITS A MASTER MAKE IT SLAVE
IF IT STILL DOESNT WORK THE CONTROLLER IC ON MOTHER BOARD CAN BE FAULTY.
Jul 28, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Two Maxtor hard drives - Master 6Y080L0 and Slave 6K040L0 Jumper set as Master for the 80 and no jumper for the 40. These are the identical settings shown printed on both drives. I beleive the...
Essential you have one license allowed and it checks the primary HD via its 'utilities function', and only does a general scan of slave. Since you did not mention Norton version nor your OS general assist here. You might consider going into Options and having it scan both HDs, worked for me.
Jun 22, 2008 | Computers & Internet
Maxtor 52049U4 20GB hard drive jumper settings
There should be a diagram showing how you should set the jumper. Set it according to what you want it to be and it should begin to should up. You can set it as Master, Slave, or Cable Select.
Nov 12, 2007 | Maxtor DiamondMax Plus D740X (6L020J1) 20...
Maxtor DiamondMax Plus 9 80 GB Hard Drive Logo
403 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
