Question about Durabrand PVS1966 Portable DVD Player
Monitor to monitor 9 pin. rounded ends cable.
I need to find where I can purchase this cable on line.
  • 1 more comment
  • Anonymous Dec 23, 2007
    We have a similar problem, but ours is with one cable gone bad that attaches to the unit and the monitor. we've tried Radio Shack and Best Buy, neither of them have this cable. We also couldn't find a Durabrand website. If you've gotten anywhere finding the cable, let us know!
  • gregoria Mar 03, 2008
    Need monitor to monitor 9 pin cable for Durabrand PVS 1966. Suggestions don't lead to one? Anyone out there have a system and/or cable for sale?
  • Byron Perez Ramirez
    Byron Perez Ramirez Dec 29, 2013
    have you found nine pin i nedd one i tried all websites
Www.18002526123.com or call the number. I found this in the manual. The cables are called EZ View cable (122-004020-208)
Posted on Mar 03, 2008
So i had the same problem, but i was able to figure it out....you go to this link http://bestbuy.partsearch.com/PartSearch.aspx?x=42&y=8&PartNumber=din+cable then you put in your model number of the portable dvd player. the cable you need is called a Din Cable. I called up the parts department at Best Buy (on the webpage) and they helped me find the compatible cable for my unit. hopefully this helps!
Posted on Jun 28, 2010
I have the same problem. Need EZ view monitor connector cable. Anybody want to sell their Durabrand PVS 1966 cable or system that works? G
  • 56 Answers
Try searching for the Durabrand website by typing in durabrand on yahoo,google,msn or any popular search engine. You also might be able to find it on e-bay or simular websites like e-bay.
Posted on Dec 21, 2007
Usb powered aoc monitor is blinking
Active USB cables boost the USB signal not the 5v power lines. After about 6 feet the 5v power lines will only provide 4-4.5 volts and this is not enough to power the monitor. For this to work you will you will need to also use a powered USB hub at the remote end by the monitor. The USB hub will supply the power and the monitor needs and the active USB cable will provide the signal.
May 03, 2012 | AOC e1649Fwu 16" LED LCD Monitor - 16:9 -...
Hello, We purchased one of your projectors and someone stole our cable for it. i would like to know what kind of replacement cable i would need to purchase. On the box it says. PJD5122 i dont know if that...
Hi!
The cable you need for your projector is a common D-sub 15 pin to D-sub 15 pin VGA cable.
It is the same kind of cable used between a PC and a LCD Monitor, with the same type of connector on both ends: VGA D-SUB with 15 pins. (so you can use one of those monitor cables)
Please let me know if it helped.
Best regards!
Aug 09, 2011 | Office Equipment & Supplies
Dear Sir, A horizontal line appears in my dell monitor, which is permanent in nature, kindly help me to get rid of this.
Check the cable (VGA cable) to the computer and see that it is fully secure and that on the cable male end, there are no bent, broken or damaged pins. Check the end that fits into the monitor and look for the same, bent pins mean that the signal is not getting through and this will result in a problem such as you describe.
Try also changing the VGA lead and seeing if that helps, also test the monitor on another computer.
If that fails, the monitor is probably ready for replacing or at least a check to see if it can be repaired
Jul 28, 2011 | Dell E173FP 17" LCD Monitor
Need wiring diagram or pinout
try tracing the user manual on the web punch in the model no ect .this should give you the answers.good luck farr64
May 08, 2009 | Televison & Video
My apple mini mac (no intel) hook up mag monitor 780
The Mac Mini has an adapter plug, DVI to VGA.
If you use the adapter and a VGA cable to the monitor there is not a noticeable difference.
Just be sure to know the resolution maximums of the MAG monitor before you think its the Mac.
Feb 15, 2009 | Mag Innovision LT776s 17" LCD Monitor
Mag monitor signal cable faulty
look into the 15 pin vga connecter care fully you will look numbers 1 to 15 which is very small it configration is as follows
1)red
2)green
3)blue
4)gnd
5)gnd
6)r return
7)g return
8)b return
9)5v from vga card
10)stand by
11)sync gnd
12)Sda(serial data)
13)Hsync
14)Vsync
15)Scl(serial clock)
at another end same letters will see take continuty and join new cable
Nov 10, 2008 | Mag Innovision InnoVision 996PF (White) 19...
Dont know how to turn on
The monitor has and adapter type power cord that plugs into the computer end of the VGA cable. Look for a small round hole at the PC end of the cable.
Jun 08, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Dell monitor cable
Can you post the Model Dell and the SKU number of the video card from your invoice?
May 27, 2008 | Dell Computers & Internet
Monitor connector bent pin
It is quite easy to straighten these pins, however the pins are quite brittle, and do not suffer bending too many times (they just snap) Does this cable unscrew at the monitor end? if you have straightened the pin on the cable but are worried that it may be a little weak on that end, swap the ends of the cable round and use the other end to plug into your computer (as it will be stronger) Also if the cable unplugs at the monitor end it can be replaced with a cable of the same type, available from most computer stockists, just take the broken cable with you for comparison Gareth
Jul 26, 2007 | MPC Computers Envision EN 5100e 15" Flat...
Durabrand PVS1966 Portable DVD Player Logo
3,376 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
