Question about Mitsubishi Televison & Video
My speaker is turned off and I do not have the
My speaker is turned off my old mitsubuishi tv model and I do not have the remote. There is no menu button.
  • 647 Answers
Get a universal remote and programme it.
Posted on Oct 02, 2009
Our old model Prima tv won't turn on after i accidentally pressed the child lock please help me
Do you have the remote control for this TV? If so, you should be able to access the menu to disable the child lock. If you don't have the original remote, you may be able to use a universal remote to access the TV's menu.
Dec 05, 2015 | Prima Televison & Video
Panasonic Model TH-50PH10UKA. Hooked up to surround sound and works well. When I connect to a second input do not get any sound, how do I turn TV speakers on or Off.
Found in menu setting of tv.are you using RCA or hdmi or optical output as these need to be set in mode setting on soundboard and tv menu settings.
Jan 03, 2015 | Panasonic Televison & Video
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
Turn off internal speakers
This is usually a menu option that you can reach with your remote. I don't have this particular TV, but if you can turn them off, it is usually a menu configuration option. Hunt around with your remote until you find the configuration menu and look for the "sound" settings.
If your TV has a headphone jack, try plugging a set of headphones into the TV to see if that disconnects the internal speakers. If it does, go to Radio Shack and buy an appropriately sized blank plug and just plug that in to the headphone jack to disconnect the speakers.
Nov 06, 2012 | Toshiba 55HT1U LCD TV
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
On our mitsubuishi vs-5041 50 inch there is a black box aroung the picture of the tv. I dont have the remote, so how do i get the television picture back?
Hello.
You can use buttons that are located in front of the TV as well.
Press "menu" button and locate "picture" or "video submenu. You can use some buttons as directional ( they have arrows that indicate where you can move highlighter on menu). To choose option you can press "Select/enter" button.
More info in your TV owner's manual.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi Televison & Video
I lose Audio from internal speakers Vizio
This issue is actually caused by my cable box. Access the audio SETTINGS on Hand held Cable Remote, and turn on the HDMI and or "Digital Audio Out" option. found on 'more' settings list. This should fix the issue. I had assumed the Cable companeis 'Boot' would have installed this feature during its initialization.
Dec 19, 2009 | Vizio SV470XVT 47 in. LCD TV
No sound from tV speakers
check your speaker, use a battery 1.5vdc tap it to speaker wire if the speaker is ok you can hear a click sound as the wire touches the battery + & - .
Sep 10, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
8-9 yr old Mitsubishi tv
Good Day,
Go into the 'menu' then advance area to the audio and turn speakers on. You must have TV's orig remote. Or go to menu:
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357". Choose reset.
Good Luck, big IRISH.
Aug 21, 2008 | Mitsubishi Televison & Video
Panasonic tv old model
curve picture and auto shutdown
May 10, 2008 | Panasonic CT-20D11 20" TV
Open Questions:
Televison & Video Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
