Question about Garden
How to put brake pads on a craftsman riding lawnmower. 1994 18HP model # 917.257562
  • 389 Answers
Look on the right hand side of the transaxle, behind the front side of the rear wheel and locate the brake arm with a long rod sticking through the top of it. Note there is a 1/2" nut in the center of the arm near the bottom.
Before you start to replace the pads, try adjusting that nut. Put the tractor in neutral on flat level surface, engine off and turn the nut in while rolling the tractor back and forth with one hand, when you can no longer move the tractor STOP and unscrew the nut 1/2 turn. Now check your brakes.
If you still don't have brakes then you go back to that same nut and remove it completely, pull the arm out of your way and you will see a round disc about 3" in diameter beneath a "yoke" There will be 2 bolts 3/*8" head in the yoke, remove those and the brake pads will be right there, one in the yoke and one behind the disc.
Hope this all makes sense to you, if not, let me know and I will try to sort it out further
Posted on Oct 02, 2009
Testimonial: "thanks alot, worked great!!"
How to replace ignition switch on model number 502.254970 craftsman riding lawnmower
should be easy pull the plug off of the switch and the old switches were bolted on the newer ones are just clipped in remove old switch put in the new one put plug back on the switch.
May 18, 2017 | Craftsman Garden
Where are the kill switches located on my Craftsman 917.256711?
most lawnmowers have one for the reverse and under the seat some have them on the brake pedal to start it if it breaks it wont start
Aug 15, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
INSTALLING CLUTCH CABLE ON CRAFTSMAN
the proper threading of cable clutch for 38 in. craftsman riding lawnmower model 271150
Mar 29, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
No brakes on craftsman dl 3000 riding mower
Check to make sure brake rod spring is connected,also pads could be bad if older mower,there are two nuts that lock into one another turn in oppisite directions to seperate then adjust back one then tighten other one .
Apr 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
199 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
