Question about Toshiba 42H81 42" Rear Projection Television
Fuzzy picture and vertical lines on right side, even after WARMING UP for 30 minutes.
  • 647 Answers
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Posted on Oct 02, 2009
My TV keeps turning itself on and the screen is all fuzzy lines when try and turn the TV on for myself it takes anything up to 30 mins and I still get the fuzzy lines then it seems to right itself and...
touch the main ic of your t con board if its getting too much heat then you have to replace that ic with new one .by this faulty ic you will see some lines on display .when it heated up this may cause lining problem
Mar 07, 2015 | Samsung LN32A330 32 in. LCD TV
Vizio M420kd vertical thin white line on left of screen pictures have lots of green ghosting
If you've ruled out that the source you're displaying from is good, I would contact vizio for a warranty repair
Jan 24, 2014 | Vizio Televison & Video
Toshiba 42h83 picture all over the place for at least 15-20 minutes. FUZZY WITH VERTICAL AND HOROZONTAL LINES Then works ok
hello!
Looks like you might have loose pins on vertical out put I.C. chip. Take care of the issue sooner, the better! Otherwise, picture will shrink permanently and you end up with big repair job. Vertical output chip attached to silver aluminum heat sink, in the middle of the chassis. You must have some soldering skills and equipment, of course. There are 13 pins at the chip. Flip chassis over and locate the chip. Be careful with wiring. If you unfasten wire clips, you will be able to get to the area, at your bottom. Use sharp tip 30 watt soldering iron. Pins are very close to each other what creates possibility of bridging adjacent pins. Use magnifier or reading glasses to complete the job. another possibility might be in a power supply area, "cold" side. some regulators might have solder joints weakened. Make sure, inspect every part attached to heat sinks. DO NOT TOUCH "hot" side of the power supply. There are charged high capacity electrolytic capacitors. If you start messing around there, quite a chance you will kill main regulator and get zapped badly! Also: slight possibility, that you may find leaked out electrolytic capacitors, which would behave in a similar way. If you see a little "puddle" near the capacitor, means: it's near empty.Most likely around "cold" side of the power supply. Replace those with same value and voltage ratings.
Good luck,
Alex.
Jan 20, 2012 | Televison & Video
Red vertical lines and horizontal flashing lines on viewing screen plus fuzzy picture.
Its bad ccd imager problem in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 02, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Picture is wavy and has black vertical and horizontal band
The following are supposed to be checked on the horizontal and vertical,
the supply of the sawtooth oscillator
eletrolitic capacitors near a line transformer
zener diodes
and driver transistor a round that area.
Apr 08, 2009 | Toshiba 35A44 35" TV
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Green vertical lines
reset the settings to factory default. the resolution doesn't match.
Nov 20, 2008 | Office Equipment & Supplies
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Video input
Needs Hyper board repair = replace bad caps
PCB not available to buy outright........................T.
Nov 10, 2007 | Toshiba 42H81 42" Rear Projection...
Picture fuzzy
I would suggest to unplug the tv from the wall for about 15 minutes and then plug it back in,and turn it on,this should reset the microprocessor and realign the colors back to normal.let Us know how it goes and if you need more help.
Oct 12, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Toshiba 42H81 42" Rear Projection Television Logo
91 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
