Question about Samsung Digimax A7 Digital Camera
HI, I have the Samsung A7 camera problems with taking photos
HI, I have the Samsung A7 camera. Lately when I switch it on the zoom lense comes out, then doesn't go back in. You EITHER have to take the batteries out to get it to turn off. Or the lights at the front of the camera go through a blue and red sequence and eventually it turns itself off. It is taking pictures when it feels like it. HELP! All my manual is in French!
SOURCE: Samsung Camera mod DIGIMAX S500/Cyber 530
still that happens to me sometimes...this is when you need t o charge your battery over again fully....
Posted on Dec 31, 2007
SOURCE: Samsung L85 camera image issues
If your camera is still under warenty here is number of the repair center in Ca. 310 632-1234. Have model number and serial of camera at hand. They may have you go on line to their web site http://www.samsungcamerausa.com/ and fill out a repair request.
Forewarned :I purchaced a L85 new before
Thanksgiving and it did not work out of the box at all. Sent in camera and it was returned on Dec. 20th. I sent the battery with camera and none was returned. After buying another battery and charging, to my frustration the camera worked only enough to extend the lens and flash the LCD screen and that's it. I am trying to get an exchange from seller but am not to confident this is going to happen. Lots of emails back and forth but no progress.
Hope you have better luck then I am having.
Posted on Jan 03, 2008
SOURCE: samsung L730 won't come on...
how about give us our money back!
Posted on Jan 09, 2009
rylee_smith
  • 8619 Answers
SOURCE: samsung pl50 lense jammed?
Hi
Thanks for using FixYa. Please check the battery is fully charged.
If you are able to access the Menu, please select Initialize under Settings and Main Settings 1 Menu and press OK. If still the issue persists, perform the power reset by removing the Battery and pressing the power button continuously for one minute. Then, leave the power button and reinsert the Battery.
To reset the Digital Camera by using a RESET button follow these steps---
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
To perform a manual power reset follows these steps---
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If still the issue persists then it means that the cabinet is opened or LCD cable is touched which is caused by connection defect or poor contact between connector and LCD cable due to the pressure by the rib in the front cabinet to the connector. If still its not resolved then as its a new one so you should use its warranty and get it replaced just to avoid future issues.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 05, 2010
  • 11967 Answers
SOURCE: Samsung L313 camera - lense is not retracting when off &...
You could return it (recommended) or try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 07, 2010
CASIO EXILIM digital camera photo resolution
The Digimax A7 Doesn't work outdoors, because on top of the camera, try taking a picture, but hold your hand on the top of your camera (Cover it) it's light sensitive. On top their is a built in sensor, the Darker it is the darker the picture is, the lighter, the lighter. If you cover it, (Usually on top) It should work fine outdoor, just don' t cover it indoor. Hope this helped. -CA
Jul 14, 2008 | Samsung Digimax A7 Digital Camera
Hi, I bought a Samsung Ex1 - F1.8 and I am wanting to buy a zoom/lens for my camera so that I can take good photos at sports games etc. I'm not sure where to buy them or what sort I need, as help would...
Youmust buy the add one lenses from the camera accessories shop but it will be good to have some knowledge of phototgraphy so that you can choose the zoom , wide angle and normal lenses combination with your taste.
If possbile try to attach and take a test before you buy so a s to confirm your need.
Sep 23, 2010 | Cameras
Can't take pictures when using zoom.
this unit need factory repair I hope you have a warranty I'm very sorry I would try calling the manufacture and explaining this to them. Good luck
Sep 16, 2009 | Cameras
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Zoom problem
sitch on when the lense extends take hold of the end and gently twist and pull the lense you may hear it click. be gentle do not force it then switch on and off again this should solve the problem
Jan 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
CAMARA SOFTWARE PROBLEM
Does your battery work with regular AA alkaline batteries ? They have higher voltage than NiMH rechargeable. I'm having a similar problem, just discovered today that my camera works fine with AA alkaline batteries.
Sep 19, 2006 | Samsung Digimax A7 Digital Camera
Samsung Digimax A7 Digital Camera Logo
63 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
