Question about LG 32LH20 32 in. LCD HDTV
My new 32" is connected directly to cable (no box) and set at 16:9 or any other and I have 3" of black on both sides. This is on any channel and show.
  • LG Master
  • 5,568 Answers
I don't know if you have landline cable or satellite but in both cases, you may not have the HD signal available unless you are paying an extra fee. HD doesn't happen in the set, it has to be available from your provider too.
Posted on Oct 02, 2009
I have cable. The autoprogram doesn't recognize any channels. It works fine when I hook up the dvr cable box, but not when I bypass the box. Trying to do away with the box.
Cable signals today are encrypted so that it is not possible to directly connect the cable to the set and get the cable channels. You must use the cable box. Some sets have what is known as a "cablecard" slot that can be used with a card from the cable company in lieu of a cable box. Only then can you use the TV tuner for cable channels.
Oct 04, 2015 | Emerson LC320EM2 32" LCD HD Television
MMy Vizio 32" tv only gets 16 channels
If your Vizio TV has a built-in HD converter, 16 channels is what you can expect. If the channels are identified with decimals such as 10.1, 10.2, etc. they are HD. The cable connection you refer to must be connected to an antenna, otherwise you would have a cable box and a monthly bill from some cable company
Dec 04, 2012 | Vizio E322VL 32 in. LCD TV
Picture ratio
Programs that are recorded in 16:9 format appear full screen on a 16:9 TV. A program recorded in a standard 4:3 format will either be stretched to fit the screen or have side bars to fill the screen area. In the case of HD channels, the black side bars are part of the picture which is being broadcasted.
Apr 22, 2010 | LG 32LG30 32 in. LCD HDTV
The whole picture does not show on the screen; faces on the edge are cut off
It's one or two problems. It depends on if you're using a cable box. First try to see if your aspect ratio is on full using the JVC remote. Just Press the Aspect button. Then if it's on full and this doesn't correct the problem it may be your cable box. If it's time Warner go into the settings by pressing the settings button on the remote twice I believe tehn go to display and select the select and check each option picture size (change to normal if you have a 4:3 t.v. or stretch if you have a 16:9 (wide screen T.V.) Then go to aspect ratio and select again eih 4:3 or 16:9. If your have a hdtv cable box select output resolution and make sure there is a bulllet next to each setting for 480i, 480p, 720p and 1080i. Then exit out of the cable settings and your picture should be ok. Now if you have the hdtv package keep in mind it is normal to have the black side bars on each side of the picture only if your watching one ofthe high definition channel network that is not actual being broadcast in hdtv or recorded in hdtv.
Oct 14, 2009 | JVC AV-32D305 32" TV
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
Mar 16, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
HDTV and cable box; no volume on channels higher than 99
Can you tell me, is the set top box connected directly to the tv? (i.e. not to a surround sound receiver or anything)
Mar 13, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Olevia LCD 32 inch
You can hook up direct but you will not get hi def channels, only the standard or digital depending on your hook up.
Oct 12, 2007 | Olevia LT32HVM 32 in. LCD Television
LG 32LH20 32 in. LCD HDTV Logo
94 people viewed this question
Computer Repairing
Computer Repairing
