Question about T-Mobile Sidekick ID Cellular Phone
My sidekick 2008 screen just went black/blank last night
However, under a bright light, I can see the phone functions, not sure how to fix it. Called T-mobile and the phone warranty expires EXACTLUY the day before my phone went black :-(
How do i change my backlight for my sidekick 2008? My screen completely went black.
The problem with your sidekick 2008 screen is the backlight is burned out. this can happen if dropped or if it gets wet.
The only way to fix it is to replace the screen. It is fairly easy to do and new ones run about 65 dollars on ebay.
Below is a guide for the replacement and a link to buy the 2008 LCD screen.
Replace the Sidekcik 2008 LCD screen
Buy Sidekick 2008 LCD Screen
Nov 05, 2009 | Cell Phones
My sidekick3 light wont turn on,
it might be something wrong with the sensor.. try to put your finger over it a few times. the sensor is on the screen opposite the T mobile logo
Aug 09, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Got my sidekick 2008 wet & now screen wont work
Hello xxlucygoosie,
First off you did the right thing, however you need to leave it for more than just a night, more like 48 hours at least,add a good amount of rice.
Replacing the screen likely would not work as you probably have damaged more than just the screen(the main board) when you tried to turn it on if there was any water in it then you shorted it out.
You will have to replace the phone if you can not dry it out more and it works on some miracle.
Sorry for your misfortune, and thank you for trying Fixya!
Apr 01, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
Sidekick Id screen.
at a t mobile company they have extra sidekick screens tell them your problem they will fix it they will wrap it for you or they put it on for you there
Jan 07, 2009 | T-Mobile Sidekick ID Cellular Phone
I dropped my sidekick 08 and the screen slowly went black
more than likely the LCD screen or backlight burned out. You can replace the LCD screen yourself for about 65 dollars which is a lot better than 200 for a new phone.
Check out the following guide
How to Replace the LCD screen on Sidekick 2008
and then check out what screen are available on ebay. These are the only ones I have been able to find for sale
Sidekick 2008 LCD Screen Replacements
Dec 27, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Blank Screen???
Is it white or just black?
If it it is white then this procedure should fix it, Fix Sidekick White LCD Screen
if it is black then a new lcd is in order. They run about 45 dollars and fairly simple to install.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
May 21, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick id
Is the screen white or black?
If it is white you may be able to fix it, black maybe not.
The following instruction for a sidekick 3 but it is the same for a sidekick ID. Just reseat your lcd instead of installing a new one.
Sidekick 3 LCD Screen Only Replacement
Mar 23, 2008 | T-Mobile Sidekick ID Cellular Phone
Screen went blank
Yep, you can replace the screen yourself.
They run between froty and fifty dollars on ebay. Most come with detailed instructions and the screwdriver you will need. A Torx T6 is what you will need to open it.
Sidekick LCD Screens
Sidekick Disassembly Instructions
Jan 03, 2008 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick ID Cellular Phone Logo
83 people viewed this question
Top T-Mobile Cell Phones Experts
Computer Repairing
Computer Repairing
SHIVAJI YADAV
SHIVAJI YADAV
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
