Question about Cortelco 2554 Corded Phone
Where can I get a free schmatic for a 2554BMP A 83041 wall phone? I want to connect to my home phone line.
    President:
  • 547 Answers
If you're in the USA, the wiring is all color coded, and for a single line you only need to connect the red and green wires.
You can get a full schematic at this link.
Posted on Oct 02, 2009
Testimonial: "I appreciate the free information!"
Trying to connect fax with my optimum (which is a triple play package) I also have wireless. The Wall jack cord is going directly into the modem. How do I connect the fax?
Your Optimum modem is acting the same as the phone company's input line to your home. The cord that goes from it to the wall jack is actually powering up all wall jacks it the home. You can:
  • Use any available wall jack in the home to cable up to the fax.
  • Split the output signal from the Optimum and connect to the splitter (may not work).
  • Run the Modem output to the LINE connection of the fax, and the EXT output of the fax to the wall jack (may not work)
Jun 28, 2015 | Office Equipment & Supplies
Rogers problems
This has become a growing problem:
  • As land lines have been reclaimed or replaced in the phone company networks;
  • As the growing older population has lost hearing sensitivity.
  • Because secondary carriers don't always receive the best or least crowded connectons (especially in case of residential versus business which pay more for service).
If you are getting static and cross talk (hearing radio or other people's converstations) notify the phone company and you will probably provided a new connection.
IF the problem is persistent without such interference, consider an amplified phone--some states (California for instance under Federal auspices) makes such equipment available free to hearing impaired. Also check the quality of your household wiring and connections.
Check with you neighbors--if they don't have the same problems, complain to the phone company. If they do, complain together.
Finally, some phones are simply too poor in quality to provide good sound. You might want to upgrade: either the phone set or its line or handset cord.
Aug 20, 2014 | Cortelco mini wall mount corded/wired home...
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
I can't figure out how to set up a voicemail or answering machine
The phone doesn't have an answering system built-in. If you use a voicemail service, you will need to check with the provider for the phone number and then follow their directions to set up your mailbox. If you are connecting a stand-alone answering machine, you will need to daisy chain the devices. Connect the phone cord from the wall jack to the answering machine IN port. Then use another phone cord from the answering machine OUT to the CL2909 TEL port. (If you are using a fax modem (or regular modem), with an anwering machine feature on your computer, then you still want to use this chain method. The data port may not let the computer answer a voice call.)
If you are using a free standing answering machine, after connecting everything together, make sure that you hear a dial tone and can properly make calls. If you do not get a dial tone, replace cables. (I recommend you check that the phone works by plugging it directly to the wall jack before doing a daisy chain of devices.) Turn on the answering machine and set the outgoing message and number of rings as per the directions for the answering machine.
If you have any problems, make sure that the line is good. I use an old rotary phone to check my service connection (at the box since that has RJ-11 connections in my home). You may want your phone company to check if the line is good to your home if the service doesn't have RJ-11 connections. If the problem is in the wiring, check the jacks (loose wire/broken wire) and exposed wiring (missing insulation/breaks). You may need a professional to check in the walls; your telephone service provider will fix this for a fee. If the problem is outside, then the provider will fix it free.
You can get the manual and guick start guide as PDF files from AT&T: http://telephones.att.com/att/index.cfm/product-detail/?ProductID=290 . The links are on the right hand side of the page.
I hope this helps.
Feb 07, 2011 | AT&T CL2909 1-Line Corded Phone
How can I send a fax through a home phone line? I was given this as a gift and I don't have manual. I was wondering if there was a way I could send a fax through my home phone line, since I don't have a...
A regular old (POTS) phone line will send/receive faxes just fine. If you want to connect it to your computer, you'll need TWO phone cords: one into the wall, and one into the computer, with both connecting into the fax machine itself. Those ports should be marked on the fax.
Feb 18, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How do I connect the fax to my home phone line. MFC 240C all in one printer
On the left side of the printer there are two telephone line connections, one is for the telephone line and the other is for the telephone extension. You will need two telephone lines, the type that have that clicker on the end, the line hole goes directly into the wall jack for the telephone and the extension line goes directly into the telephone that you had plugged into the wall. Try that, it works.
Feb 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
I'm confused on how to hook up the phone that came with the all in one. also does the telephone company have to do something for me
No you hook up the Hp to the phone line using a phone cord and your all in one can send and recieve faxes anytime and auto answer. If you have a 2 wire cable box for internet highspeed you will have to put a filter on it and you can get that from the phone company for free. So if you have a phone splitter you can have the fax on the same line as your phone and your computer.
Nov 13, 2009 | HP Officejet 5610 All-In-One InkJet...
I HAVE A W136C Jenn-Air wall oven and would like a wiring connection diagram. Icant figure where to connect the orange wire
Look for schmatic behind control panel, open oven door and remove 4 screws that hold upper face panel down, panel should slide up 1/2' or so and lift off.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
3 speed switch wiring schmatic
On a 3 speed switch you usually have 4 terminals, and they are marked L1, 1, 2 and 3.
L1 which is line voltage from the electrical cord or wall plug, #1 low speed usually a red wire from motor, #2 medium speed usually a blue wire from the motor and #3 high speed usually a black wire from the motor. That is if the fan is low,medium and high, if it says high, medium and low then reverse #1, #2 and #3
May 08, 2009 | Heating & Cooling
We have a number of phones in the house....none works. When the phone is picked up all you get is a buzzing sound
This could be any number of things here are a few ideas to help isolate the problem:
  1. Disconnect all phones from the wall jacks
  2. Connect a phone to each wall jack, one at a time and test. This will help you determine if one of the all jacks is bad. Use the same phone for testing each jack. If you have a phone that does not require AC power, use that phone to test. If the same phone works at every wall jack, one of your phones is bad. You can now test each phone alone until you find the bad phone.
  3. If after testing each wall jack, you still have buzzing on the line you will need to contact the telephone company to test the line coming into the house or apartment.
  4. If you live in a house and can access the "box" where the phone lines enter the house, there is usually a jack where you can plug the test phone into and check the lines BEFORE they enter your home.
  5. If you test at the entry box and your phone works, you have a problem with the wires in your home. If you still have the buzzing, it is probably a telephone company problem
Good Luck!
Aug 11, 2008 | Lands Phones
Cortelco 2554 Corded Phone Logo
160 people viewed this question
Top Cortelco Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Cortelco Lands Phone Expert? Answer questions, earn points and help others
