Question about Epson Stylus Color 670 InkJet Printer
The pink colour is missing every time i clean the
The pink colour ink on the print out is missing every time I clean the print heads, the printer is used regulary
  • 184 Answers
Probably one of the red cartridges is empty or near empty or possibly the yellow - it will miss whatever color is low or empty or substitute the next closest shade using the remaining colors if one is out.
Posted on Oct 02, 2009
When i print something in colour the red comes out pink and not red
I'm sure you have tried this, but you may have to run the "clean print head" several times to clean all the ink jets. I had a similar problem on my 3640 and had to run the clean cycle about 20 times. If you feel you are capable, you can also remove the print head and do a manual clean. YouTube has a few videos on how to do it.
May 09, 2016 | Epson WorkForce WF-3640 Wireless Color...
Epson xp 305 help
It's quite likely that at some point in time you will have attempted to print in black only to receive an error message that you cannot print until a colour cartridge is replaced.
"If ink is not in the tubes from the head to the cartridge, air will be sucked in and therefore cause damage to the print head. This is because the nozzles are in the print head and not in the cartridge. "
What Epson are basically saying is... if this safeguard was not in place, and you sent a print request for black when a colour cartridge was empty, there is a risk of air being pulled into the printhead. This air will ruin the vacuum effect needed for the printhead to pull ink in, meaning your printhead would be at risk of never printing again.
Additionally, if any air is allowed go get into the aformentioned tubes from the head to the cartridge, any remaining ink will coagulate. Just in case you're not a scientist - coagulation in a tube/cartridge is bad, and will lead to you not being able to print again with that cartridge, or to a blocked nozzle/printhead which will require a significant amount of cleaning cycles to budge.
Aug 08, 2014 | Epson Expression XP-305 Inkjet...
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Lexmark Z615 inkjet printer - whetther I print in colour or black and white, I am getting whole lines of text/image missing. When I use the "clean nozzle" function some of the colours - like...
The problem with your printer is the print head. Usually you have to run the clean nozzle thing 5 or 6 times to clean the print head nozzles and if there's still no improvement after that then print head needs to be changed for the printer to work properly. The bad news is that a print head costs almost as much as a new printer.
Jan 30, 2011 | Lexmark Z615 InkJet Printer
Just chaned ink cartridge and every thing printed out pink clean the pink and now nothing is printing tried cleaning the head and did the nozzle check and still not printing
It seems to me, if you have changed your colour cartridge that is, that you do not have enough black ink in your black ink cartridge, so you should change this also.
Barbara Grey
Oct 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Hi, I have a Canon Pixma MP560, and whenever I try and print something in black and white it comes out with a pink tint to it. Hope you can help.
Possible that the Ink cartridge or the head is faulty. Ink drying can make this imbalance of colours , so check to correct with the properties of the printer, If not clean several times to see any changes come about with a test print.
The last can be the ink/head unit.
Sep 20, 2010 | Canon Office Equipment & Supplies
When I print out picture, pictur came out so many pink stripe across the picture.
There probably is nothing wrong with your PINK ink-cartridge.
It's one (or two) of the other colour ink-cartridges that either are EMPTY or having CLOGGED ink-jet mechanisms.
Run a "print-head-cleaning" cycle.
Aug 27, 2010 | Epson Stylus 1400 InkJet Photo Printer
Replaced cartridges
keep cleaning untill it starts to print clearly, you may reuse the same paper for that purpose, if you don't see any progress after 10 cleans, consider getting lasser printers, they are immune to print head drying and save alot of money on ink replacements. go with brother color or black and white series. I switched and don't have problems anymore
May 20, 2009 | Canon i450 - Printer - color - ink-jet -...
Color Printing Problem
Remove all ink cartridges and replace them securely in position.That may be the problem always.
Print nozzle check pattern.See for any missing patterns
Give a head cleaning
Again print nozzle check pattern.If it is ok leave it, other wise give a deep cleaning
  1. If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
  2. Atleast a multi colour( like your visiting card) page should be printed in a week time. other wise the ink may clog in the head.
Mar 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
Epson Stylus Color 670 InkJet Printer Logo
190 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
