Question about Princeton Digital VL2018W Monitor
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? When it's turned on, the light on my monitor blinks but the screendoesn't display anything. Why might this be happening, and how can Ifix it?
  • 10 more comments
  • Debra C Dec 29, 2007
    I have tried another computer and the same thing occurred. Is there any other method, maybe a sleep mode that hitting several buttons would cause it to turn off?
  • Anonymous Mar 15, 2008
    I have the same problem and I have tried 2 different cpu's and both inputs.
    there is one on ebay for sale with the same problem.
  • waterider Mar 15, 2008
    Same problem here, I have tried 2 cpu's and both inputs.
    There is one on ebay for sale with the same problem.
  • Anonymous Mar 18, 2008
    Princeton monitors are just not any good. This is my second one to just die.
  • crisg24 Mar 19, 2008
    mine also. whenever i go to boot up my computer in the morning, then turn on my monitor, the blue light on the monitor blinks, as well as the "blank" screen. I can not get it to display a picture whatever i do...very frustrating....
  • BarrySolomon Apr 17, 2008
    I have the same issue. Called Princeton and the guy said to unplug all cables. Plug the power back in in a few. Turn it on. Let it go into sleep mode (orange light) and then plug in monitor from computer. I did this and nothing happened. He said it was a power supply issue.
  • slipin2itxxx Jun 30, 2008
    have princeton VL2018w had it approx 2 months, got up one day and monitor flashes real quick on then goes black flashes on then goes black...called princeton tech said it was a power supply problem. Princeton sucks!
  • help_hpl Jul 22, 2008
    no display after turn On the monitor .cpu is working with other monitor properly. And this monitor have the problem with other systems also.
  • gemsahin Aug 14, 2008
    when i turn the pc I can see the start up screen until up to the windows screen and then it goes black. Some times the light comes on but no display.I changed the settings in my pc, Then I got my screen and when it goes to sleep i cant get the screen to come up.
  • Anonymous Aug 20, 2008
    when the monitor is on it will blink on and off every 5 seconds this is very annoying do you have a fix/
  • rking280960 Oct 10, 2008
    Princeton Digital VL2018W Monitor this monitor will power on but will not show a picture
  • Kyle Steven OHare
    Kyle Steven OHare May 11, 2010
    Same problem with the VL2018W here ; the blue light just blinks / flashes repeatedly. When you take the input out, the monitor still displays the 'no input' message as well.
    MTSPACE:
    YES, the monitor is connected to a computer, which is ON.  Try asking a good question - like have I tried (both) inputs on the LCD?
REPLACE THE 3-470UF 25V CAPACITORS WITH R-SHACK
470UF 50V CAPS WORK GREAT!!!!!!!!!!!!!!
Posted on Apr 07, 2008
    Problem Solver:
  • 15 Answers
I replaced the capacitors which had bulging vents and it worked. Here is a page that has pictures of the process on a similar model: http://www.thisoldtractor.com/gtbender/princeton_graphics_vl1918_monitor_repair.htm d('T09PULG0w7S/fX98fn0=').
Posted on Aug 24, 2009
  • 3 Answers
It is a power supply/inverter board problem. The capacitors go bad (see solution #2). Replacement of this board will fix the problem.
Posted on Jul 07, 2008
I have the same problem as posted by (jaldeep) on dec 21,2007
ralph-d
Posted on Oct 19, 2008
  • ralph-d Oct 19, 2008
    I replaced the 3 capacitors as it was suggested and it works great !!!!!!
    Ralph-d
The tech support people at Princeton say it is a power supply problem. The unit comes with one year warranty so if it is less than a year you should be covered. A replacement board costs $75 plus shipping from www.lcdparts.net. I would like to try solution #2 first (replace the 3 capacitors with Radio Shack capicators) but I got to figure out how to get into the monitor.
I removed all the screws but it is still tight as a drum.
Posted on Aug 16, 2008
I have the blinking power light problem, but I can help the person who asked how the thing comes apart. Once the screws have been removed, the back and front halves of the monitor are snapped together. Use a side screwdriver to pry the two parts apart. There are two spots where there is a slightly wider gap (probably for this purpose) - start there and work your way gradually a couple of inches at a time all the way around the monitor and it will pop apart.
I will be trying the capacitor replacement shortly.
Posted on Sep 21, 2008
I just started having the same problem - all is properly connected.
Posted on Dec 22, 2007
    Problem Solver:
  • 12 Answers
So far i can tell its not the power supply. i think it has a motherboard issue. i will post when i find a solution.
Posted on Apr 05, 2008
    Scholar:
  • 103 Answers
Is the monitor connected to the computer?
Is the computer turned on?
Have you checked to see if the monitor works when plugged into another computer?
Posted on Dec 21, 2007
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Monitor : no display and blue led light is blinking
The power supply is the first thing that the 110v electric line goes into. The invertor is the next item past the power supply, or sometimes contained within it. I do not thing monitors are a DIY repair.      First substitute a different monitor to confirm that it is, in deed , the monitor and not the video card.
Jan 14, 2009 | Advueu Technology ADV178T 17" Flat Panel...
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
Princeton Digital VL2018W Monitor Logo
1,074 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
